Please help me with audio problem.
    This is my laptop: http://b2b.sony.com/Solutions/b2b/da...15b4aad33c.pdf
    Ok, here's the jist. I installed Ubuntu, during the installation i had to disable acpi fo rit to install. Once it was installed i was having major problems with playing video and my audio was stuttering horribly. So after a couple hours of googling and playing with pulseaudio and my video driver i was able to play video but the stuttering problem was still there. I found out this was a wide spread issue with Ubuntu, so i formatted and installed Kubuntu. During the installation i had to do the same thing, disable acpi for it to install (acpi shouldn't be related to the audio problem, i just thought it was worth mentioning) and when i booted up everything was running smooth. I didn't have to tinker around with my video properties in order to get it running. But when i tried playing a video there was no sound and when i tried playing just an audio file it stutters forribly. I googled around a bit more but i can't seem to find a solution. I've tried setting everything to ASLA audio, i'v tried using different media players, i've tried setting the audio to different channels all to no avail. What is my problem? Do i need new drivers? If i do where can i get them? I'm pretty nooby with linux atm so detailed fixes would be very appreciated.
    So to sum things up the main problem i am having right now is when i play mp3's or any other audio file the sound stutters/freezes until i restart and when i play a video file i have good video but no audio.
    Re: Please help me with audio problem.
    Welcome.
    That pdf doesn't give much info on the audio for that laptop huh?
    in a terminal, do a sudo lshw and copy what it says about your audio and post it back here.
    (you might have to install lshw first from Adept)
    &quot;Either you repeat the same conventional doctrines everybody is saying, or else you say something true, and it will sound like it&#39;s from Neptune.&quot; ~Noam Chomsky<br /><br />Gigabyte MB, AMD 64x2 6000, 2 Gigs Patriot DDR2, XFX GeForce 8600GT XXX, 400Gig WD SATA HDD &amp; 1TB WD SATA HDD.
      how >.>;;
        KDE 3.5 in Kmenu >System >Adept pacakge manager. do a search for lshw. check it then click full upgrade, then apply changes. (if I remember right)
        After that is installed open Konsole and type sudo lshw, enter password (cursor will not move), then hit enter. It will give you all of your hardware info. Copy and paste the section for your audio device here in the forum.
          Thank you, heres the info:
          chad-laptop
          description: Notebook
          product: VGN-N385E
          vendor: Sony Corporation
          version: C3LPQ01P
          serial: 28204330-3007432
          width: 32 bits
          capabilities: smbios-2.4 dmi-2.4 smp-1.4 smp
          configuration: boot=normal chassis=notebook cpus=2 uuid=1BCDF140-4300-11DC-8914-001A80452BB4
          *-core
          description: Motherboard
          product: VAIO
          physical id: 0
          version: N/A
          serial: N/A
          slot: ��@
          *-firmware
          description: BIOS
          vendor: Phoenix Technologies LTD
          physical id: 0
          version: R0100J4 (02/08/2007)
          capacity: 960KiB
          capabilities: pci pnp upgrade shadowing escd cdboot bootselect edd int9keyboard int10video acpi usb agp smartbattery biosbootspecification netboot
          *-cpu:0
          description: CPU
          product: Intel(R) Core(TM)2 CPU T5300 @ 1.73GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: 6.15.2
          serial: 0000-06F2-0000-0000-0000-0000
          slot: N/A
          capacity: 1733MHz
          width: 64 bits
          clock: 133MHz
          capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx x86-64 constant_tsc arch_perfmon pebs bts pni monitor ds_cpl est tm2 ssse3 cx16 xtpr lahf_lm
          configuration: id=0
          *-cache:0
          description: L1 cache
          physical id: 5
          slot: L1 Cache
          capacity: 64KiB
          capabilities: internal write-back data
          *-cache:1
          description: L2 cache
          physical id: 6
          slot: L2 Cache
          capacity: 2MiB
          capabilities: internal write-back unified
          *-cache:2 DISABLED
          description: L3 cache
          physical id: 7
          slot: L3 Cache
          *-logicalcpu:0
          description: Logical CPU
          physical id: 0.1
          width: 64 bits
          capabilities: logical
          *-logicalcpu:1
          physical id: 0.2
          width: 64 bits
          *-memory
          description: System Memory
          physical id: 9
          slot: System board or motherboard
          *-bank:0
          description: SODIMM
          physical id: 0
          slot: SODIMM1
          width: 64 bits
          *-bank:1
          description: SODIMM
          physical id: 1
          slot: SODIMM2
          width: 64 bits
          *-cpu:1
          physical id: 1
          bus info: cpu@1
          version: 6.15.2
          capabilities: ht
          configuration: id=0
          *-logicalcpu:0
          physical id: 0.1
          *-logicalcpu:1
          physical id: 0.2
          *-pci
          description: Host bridge
          product: Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 03
          width: 32 bits
          clock: 33MHz
          configuration: driver=agpgart-intel module=intel_agp
          *-display:0 UNCLAIMED
          description: VGA compatible controller
          product: Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller
          physical id: 2
          bus info: pci@0000:00:02.0
          version: 03
          width: 32 bits
          clock: 33MHz
          capabilities: msi pm vga_controller bus_master cap_list
          configuration: latency=0
          *-display:1 UNCLAIMED
          description: Display controller
          product: Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
          physical id: 2.1
          bus info: pci@0000:00:02.1
          version: 03
          width: 32 bits
          clock: 33MHz
          capabilities: pm bus_master cap_list
          *-multimedia
          description: Audio device
          product: 82801G (ICH7 Family) High Definition Audio Controller
          physical id: 1b
          bus info: pci@0000:00:1b.0
          version: 02
          width: 64 bits
          clock: 33MHz
          capabilities: pm msi pciexpress bus_master cap_list
          configuration: driver=HDA Intel latency=0 module=snd_hda_intel
          *-pci:0
          description: PCI bridge
          product: 82801G (ICH7 Family) PCI Express Port 1
          physical id: 1c
          bus info: pci@0000:00:1c.0
          version: 02
          width: 32 bits
          clock: 33MHz
          capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
          configuration: driver=pcieport-driver
          *-network
          description: Ethernet interface
          product: 88E8036 PCI-E Fast Ethernet Controller
          vendor: Marvell Technology Group Ltd.
          physical id: 0
          bus info: pci@0000:02:00.0
          logical name: eth0
          version: 16
          serial: 00:1a:80:45:2b:b4
          capacity: 100MB/s
          width: 64 bits
          clock: 33MHz
          capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
          configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.20 firmware=N/A latency=0 link=no module=sky2 multicast=yes port=twisted pair
          *-pci:1
          product: 82801G (ICH7 Family) PCI Express Port 2
          physical id: 1c.1
          bus info: pci@0000:00:1c.1
          version: 02
          width: 32 bits
          clock: 33MHz
          *-pci:2
          product: 82801G (ICH7 Family) PCI Express Port 3
          physical id: 1c.2
          bus info: pci@0000:00:1c.2
          version: 02
          width: 32 bits
          clock: 33MHz
          *-network
          description: Wireless interface
          product: PRO/Wireless 3945ABG Network Connection
          physical id: 0
          bus info: pci@0000:06:00.0
          logical name: wmaster0
          version: 02
          serial: 00:1b:77:a1:4b:bc
          width: 32 bits
          clock: 33MHz
          capabilities: pm msi pciexpress bus_master cap_list logical ethernet physical wireless
          configuration: broadcast=yes driver=iwl3945 ip=192.168.0.193 latency=0 module=iwl3945 multicast=yes wireless=IEEE 802.11g
          *-usb:0
          description: USB Controller
          product: 82801G (ICH7 Family) USB UHCI Controller #1
          physical id: 1d
          bus info: pci@0000:00:1d.0
          version: 02
          width: 32 bits
          clock: 33MHz
          capabilities: uhci bus_master
          configuration: driver=uhci_hcd latency=0 module=uhci_hcd
          *-usb:1
          product: 82801G (ICH7 Family) USB UHCI Controller #2
          physical id: 1d.1
          bus info: pci@0000:00:1d.1
          version: 02
          width: 32 bits
          clock: 33MHz
          *-usb:2
          product: 82801G (ICH7 Family) USB UHCI Controller #3
          physical id: 1d.2
          bus info: pci@0000:00:1d.2
          version: 02
          width: 32 bits
          clock: 33MHz
          *-usb:3
          product: 82801G (ICH7 Family) USB2 EHCI Controller
          physical id: 1d.7
          bus info: pci@0000:00:1d.7
          version: 02
          width: 32 bits
          clock: 33MHz
          capabilities: pm debug ehci bus_master cap_list
          configuration: driver=ehci_hcd latency=0 module=ehci_hcd
          *-pci:3
          product: 82801 Mobile PCI Bridge
          physical id: 1e
          bus info: pci@0000:00:1e.0
          version: e2
          width: 32 bits
          clock: 33MHz
          capabilities: pci subtractive_decode bus_master cap_list
          *-pcmcia
          description: CardBus bridge
          product: PCIxx12 Cardbus Controller
          vendor: Texas Instruments
          physical id: 3
          bus info: pci@0000:08:03.0
          version: 00
          width: 32 bits
          clock: 33MHz
          capabilities: pcmcia bus_master cap_list
          configuration: driver=yenta_cardbus latency=176 maxlatency=5 mingnt=192 module=yenta_socket
          *-firewire
          description: FireWire (IEEE 1394)
          product: PCIxx12 OHCI Compliant IEEE 1394 Host Controller
          physical id: 3.1
          bus info: pci@0000:08:03.1
          version: 00
          width: 32 bits
          clock: 33MHz
          capabilities: pm ohci bus_master cap_list
          configuration: driver=ohci1394 latency=64 maxlatency=4 mingnt=3 module=ohci1394
          *-storage
          description: Mass storage controller
          product: 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
          physical id: 3.2
          bus info: pci@0000:08:03.2
          version: 00
          width: 32 bits
          clock: 33MHz
          capabilities: storage pm bus_master cap_list
          configuration: driver=tifm_7xx1 latency=64 maxlatency=4 mingnt=7 module=tifm_7xx1
          *-isa
          description: ISA bridge
          product: 82801GBM (ICH7-M) LPC Interface Bridge
          physical id: 1f
          bus info: pci@0000:00:1f.0
          version: 02
          width: 32 bits
          clock: 33MHz
          capabilities: isa bus_master cap_list
          *-ide:0
          description: IDE interface
          product: 82801G (ICH7 Family) IDE Controller
          physical id: 1f.1
          bus info: pci@0000:00:1f.1
          logical name: scsi0
          version: 02
          width: 32 bits
          clock: 33MHz
          capabilities: ide bus_master emulated
          configuration: driver=ata_piix latency=0 module=ata_piix
          *-cdrom
          description: DVD-RAM writer
          product: DVD-RAM UJ-850S
          vendor: MAT****A
          physical id: 0.0.0
          bus info: scsi@0:0.0.0
          logical name: /dev/cdrom
          logical name: /dev/dvd
          logical name: /dev/scd0
          logical name: /dev/sr0
          version: 1.60
          capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
          configuration: ansiversion=5 status=open
          *-ide:1
          product: 82801GBM/GHM (ICH7 Family) SATA IDE Controller
          physical id: 1f.2
          bus info: pci@0000:00:1f.2
          logical name: scsi2
          version: 02
          width: 32 bits
          clock: 66MHz
          capabilities: ide pm bus_master cap_list emulated
          *-disk
          description: ATA Disk
          product: Hitachi HTS54161
          vendor: Hitachi
          physical id: 0.0.0
          bus info: scsi@2:0.0.0
          logical name: /dev/sda
          version: SBDO
          serial: SB3DB1EWGR56PE
          capabilities: partitioned partitioned:dos
          configuration: ansiversion=5 signature=56c3f473
          *-volume:0
          description: EXT3 volume
          vendor: Linux
          physical id: 1
          bus info: scsi@2:0.0.0,1
          logical name: /dev/sda1
          logical name: /
          logical name: /dev/.static/dev
          version: 1.0
          serial: 955fe31e-dab5-4aac-a24a-087f6a5458ee
          capacity: 108GiB
          capabilities: primary bootable journaled extended_attributes large_files huge_files recover ext3 ext2 initialized
          configuration: created=2008-10-01 11:17:43 filesystem=ext3 modified=2008-10-01 13:47:08 mount.fstype=ext3 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2008-10-01 13:29:06 state=mounted
          *-volume:1
          description: Extended partition
          physical id: 2
          bus info: scsi@2:0.0.0,2
          logical name: /dev/sda2
          capacity: 2933MiB
          capabilities: primary extended partitioned partitioned:extended
          *-logicalvolume
          description: Linux swap / Solaris partition
          physical id: 5
          logical name: /dev/sda5
          capacity: 2933MiB
          capabilities: nofs
          *-serial UNCLAIMED
          description: SMBus
          product: 82801G (ICH7 Family) SMBus Controller
          physical id: 1f.3
          bus info: pci@0000:00:1f.3
          version: 02
          width: 32 bits
          clock: 33MHz
            ok, a quick search on the ALSA sight yielded this..
            http://www.alsa-project.org/main/ind...odule-intel8x0
            also, a couple quick questions... which version of Kubuntu are you running?
            After you installed did you run the updates? Sometimes doing this will solve some smaller issues.
            in Adept, fetch updates and do a full upgrade to install all upgraded packages.
            If that does not help with the audio, try the link I gave to the Alsa site.
              I'm running 8.04
              In adept it won't allow me highlight/click full upgrade, but i did update right after install so that might be the issue. I'm gonna give the Alsa site a try, it's confusing, but that's not gonna stop me from trying...
                With the version of Adept you are using you have to click on Fetch Updates first, then if there are any updates or upgrades you will be able to click on the full upgrade.
                You can also run updates and upgrades from the command line, which some people actually prefer.
                In Konsole type sudo apt-get update, enter password. Then do sudo apt-get upgrade.
                from what I can tell, there have been bug reports on the audio device you have.
                But the Alsa site should help. Everything appears to be done from the command line in Konsole.
                Good luck, and if you have anymore issues just post back here.
                  In Konsole type sudo apt-get update, enter password.&#160; Then do sudo apt-get upgrade.
                  But the Alsa site should help.&#160; Everything appears to be done from the command line in Konsole.
                  Good luck, and if you have anymore issues just post back here.&#160; &#160;
                  Sorry its taken soo long to respond, i had to go to class. I ran the command and it seems my PC was already up to date. I started to try and use the Asla guide but it seems the commands don't work and i don't know exactly which ones i should be suing. I'll keep trying though...
                  Edit: I keep getting an "access denied" error when i try to create a new directory (either manually or via command) in usr/src folder.
                    are you running 64 or 32 bit Kubuntu?
                      32bit
                      Also, i figured out i needed to type sudo before everything in order to use admin privileges, but even doing this i can only make the alsa dir. Allt he steps after that don't work. Is there a way someone can just make the folder and i can just paste it in my /usr/src/ dir?
                        in Adept, do a search for Alsa and check that you have the lib32asound2 (for 32bit) installed.
                        you can look through all of the Alsa programs, make sure you have the alsa-base and linux-sound-base
                        if none of this helps and that link I provided does not help, it might be better to switch from Alsa to Pulseaudio-esound
                          Thanks, i'll try these solutions. On another note is there any other destro that is proven to be working with my specs? I'd be more then willing to install a different one if that's the case.
                            not sure about another distro. There are so many of them. If you want to check out some others you can go to www.distrowatch.com and check out the different distro's in there.
                            just to be sure though, check out this link and see if there is anything in there that helps.
                            http://www.alsa-project.org/~valenty...i-HOWTO-7.html
                            it might be something simple like just installing the alsa oss package for backward comptability.
                            I will keep searching to see if I can find anything else.
                            [edit] SEE POST BELOW
                              just to be more thorough, what is the output if you enter in Konsole sudo lspci?
                              [edit] I ended up finding some people who have solved the problem you are having here.
                              http://www.uboontu.com/results.htm?c...sa=Search#1126
