Please help me with audio problem.
    Re: Please help me with audio problem.
    Originally posted by CVPunk
    just to be more thorough, what is the output if you enter in Konsole sudo lspci?
    [edit] I ended up finding some people who have solved the problem you are having here.
    http://www.uboontu.com/results.htm?c...sa=Search#1126
    00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
    00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
    00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
    00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
    00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
    00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
    00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
    00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
    00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
    00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
    00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
    00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02)
    00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02)
    00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
    02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8036 PCI-E Fast Ethernet Controller (rev 16)
    06:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
    08:03.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
    08:03.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller
    08:03.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
    chad@chad-laptop:~$
    Edit: I did a couple things in this : http://www.alsa-project.org/~valenty...i-HOWTO-7.html and it seemed to work, i got half way through playing a song smoothly but then it the audio started lagging/stuttering/freezing and the only way for me to get rid of the stuttering sound was to do a hard reboot.
      ok, it looks like Intel 82801g, so that is correct.
      check out the link I posted, some people have the same chipset and have solved their problem with this audio device.
      &quot;Either you repeat the same conventional doctrines everybody is saying, or else you say something true, and it will sound like it&#39;s from Neptune.&quot; ~Noam Chomsky<br /><br />Gigabyte MB, AMD 64x2 6000, 2 Gigs Patriot DDR2, XFX GeForce 8600GT XXX, 400Gig WD SATA HDD &amp; 1TB WD SATA HDD.
        I did even more digging and found a comprehensive audio guide here...
        http://ubuntuforums.org/showthread.php?t=205449
