Dual OS boot up problem
    Hi all, I have a problem with my Acer Aspire 721 and hoping someone would be able to help.
    This isn't EXACTLY a kubuntu issue, although I wonder if anyone with a similar set up has had a similar problem.
    The system has been partitioned and running dual boot windows 7 and Kubuntu Natty without a problem for the last month.
    Last night I ran a system update which caused windows 7 to crash on boot up from then on. : I have run the Acer eRecovery to revert windows to factory defaults.
    Now when I try to run windows I get:
    error: no such device : B408884908880D14
    error: no such disk.
    Kubuntu still runs perfectly fine, I can even access the windows partition while in kubuntu and see that the files all seem to be there.
    I guess it has something to do with the GRUB? However, I'm certainly not the most tech-savvy, so if anyone can suggest anything to try I would be really grateful.
    Thanks
    Re: Dual OS boot up problem
    I'm amazed that the Acer recovery didn't wipe grub altogether. I would assume that the recovery changed the UUID of the windows partition except that number is half as long as a UUID would be.
    Open a terminal and type sudo blkid and post the out put, then make a copy of your /boot/grub/grub.cfg file and attach it to your reply. I think you'll have to rename it .txt to attach it (Attaching is an option under Additional Options, just below and left of the posting window).
    If you're sure enough of your own skills, compare the UUID's in grub.cfg to the output of blkid and see if there are any "strangers" in grub.cfg.
    Likely, running sudo update-grub would fix any UUID changes, if that is in fact what's wrong.
      AHA!
      I ran the grub update and it seems to have sorted the problem out.
      Such a simple solution it feels almost embarrassing , but thank you so much for your help!
        Great! I love the easy ones... 8)
          I spoke too soon!
          I ran windows and all seemed fine. Restarted the system and now it won't boot from the HD, the computer just restarts after a couple of seconds.
          I can run kubuntu from the live usb still and can access file on the HD.
          Reinstalled and updated grub (windows did remove it in the end) but doesn't seem to have any effect.
          Can anyone suggest anything to remedy this?
            Could a guy just change the UUID pointers in fstab to straight /dev/sd** notation?
            The unjust distribution of goods persists, creating a situation of social sin that cries out to Heaven and limits the possibilities of a fuller life for so many of our brothers. -- Archbishop Jorge Mario Bergoglio of Buenos Aires (now Pope Francis)
              Yes.
              As far as the OP: When you say it won't boot from the hard drive - you mean grub doesn't work or you can't boot an OS?
                After displaying the ACER screen for a couple of seconds, the screen goes blank and the system restarts (unless I have the live USB connected, in which case it loads from that).
                I'm not sure if that means there is an issue with the grub, or something else.
                Not really sure what this means?
                  He means replacing "UUID=..." in /etc/fstab with "/dev/sda2" - the older way of doing it. For the record, you can also mount using labels or ID's.
                  As far as the ACER, boot to the USB, mount your Kubuntu partition somewhere (I'll use /mnt for my example) and try:
                  sudo grub-install --root-directory=/mnt /dev/sda
                  and try again (unless you get an error).
                    Right. I had a similar problem where the OS couldn't find a particular partition. I saw that the UUID's didn't match up, so I just changed "UUID=***" to /dev/* and everything work well.
                      and or run
                      sudo blkid
                      and get the corect UUID
                        I read some (grub or kernel) documentation somewhere that using UUID's is of little or no value in a single machine environment.
                        I use because it is the default, but you can change your system back to the "old" way.
                        I think if you are a distro-hopper that installs to a partition often that having to edit all your fstab's would be tiresome.
                          I've done this now, instead of restarting itself it now comes to a screen
                          [ mininal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists the possible completions of a device/filename. ]
                          grub>
                          I tried command 'boot' and got message Error 8: Kernel must be loaded before booting
                          I also tried to manual amend the fstab file, the UUIDs were wrong, but kept getting denied access to save it
                          I guess I'm doing something wrong still
                            Could anyone suggest what has gone wrong?
                            Thanks
                              fire up the Kubuntu live cd/USB and post the outputs of these commands ran in a terminal.
                              sudo fdisk -l
                              and
                              sudo blkid
                              if you can get into the Kubuntu install with dolphin post the contents of
                              /boot/grub/grub.cfg
                              it sounds like you have been successful at reinstalling grub to the MBR of the primary drive but grub cant find it's setup files (grub.cfg)
                              hears a good read on the subject of grub https://help.ubuntu.com/community/Gr...alling%20GRUB2
                              especially the section...." Troubleshooting Preparation "
