Re: Dual OS boot up problem
From Konsole:
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/sda: 250.1 GB, 250059350016 bytes
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x80398039
Device Boot Start End Blocks Id System
/dev/sda1 1 1658 13312000 27 Unknown
/dev/sda2 * 1658 1671 102400 7 HPFS/NTFS
/dev/sda3 1671 13134 92080539 7 HPFS/NTFS
/dev/sda4 13134 30402 138700801 f W95 Ext'd (LBA)
/dev/sda5 13134 15794 21366784 83 Linux
/dev/sda6 15794 16152 2876416 82 Linux swap / Solaris
/dev/sda7 16153 30402 114455552 7 HPFS/NTFS
Disk /dev/sdb: 1967 MB, 1967128576 bytes
61 heads, 62 sectors/track, 1015 cylinders
Units = cylinders of 3782 * 512 = 1936384 bytes
Disk identifier: 0x000e1496
/dev/sdb1 * 1 1015 1919334 c W95 FAT32 (LBA)
ubuntu@ubuntu:~$ sudo blkid
/dev/loop0: TYPE="squashfs"
/dev/loop1: UUID="b76bac8e-dd23-46be-82ae-3ef625826c92" TYPE="ext3"
/dev/sda1: LABEL="PQSERVICE" UUID="DAA41C49A41C2B11" TYPE="ntfs"
/dev/sda2: LABEL="SYSTEM RESERVED" UUID="3080CF3280CEFD7A" TYPE="ntfs"
/dev/sda3: LABEL="ACER" UUID="461CD9341CD9202B" TYPE="ntfs"
/dev/sda5: UUID="9396f4d4-00eb-4408-b0b6-81d2cabe9bd5" TYPE="ext4"
/dev/sda6: UUID="ae501df1-3b66-4915-9a0a-b49c5292ce27" TYPE="swap"
/dev/sda7: LABEL="New Volume" UUID="066611086610F9DF" TYPE="ntfs"
/dev/sdb1: UUID="5DD0-3C8E" TYPE="vfat"
ubuntu@ubuntu:~$
sda5 has Kubuntu installed
sda3 is windows 7
sda7 is a partition to store files
This is the grub.cfg file in /boot/grub/
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(/dev/sda,msdos5)'
search --no-floppy --fs-uuid --set=root 9396f4d4-00eb-4408-b0b6-81d2cabe9bd5
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=en_GB
insmod gettext
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 0,71,115; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Ubuntu, with Linux 2.6.38-11-generic' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
set gfxpayload=$linux_gfx_mode
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.38-11-generic root=UUID=9396f4d4-00eb-4408-b0b6-81d2cabe9bd5 ro quiet splash vt.handoff=7
initrd /boot/initrd.img-2.6.38-11-generic
menuentry 'Ubuntu, with Linux 2.6.38-11-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
echo 'Loading Linux 2.6.38-11-generic ...'
linux /boot/vmlinuz-2.6.38-11-generic root=UUID=9396f4d4-00eb-4408-b0b6-81d2cabe9bd5 ro single
echo 'Loading initial ramdisk ...'
submenu "Previous Linux versions" {
menuentry 'Ubuntu, with Linux 2.6.38-8-generic' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.38-8-generic root=UUID=9396f4d4-00eb-4408-b0b6-81d2cabe9bd5 ro quiet splash vt.handoff=7
initrd /boot/initrd.img-2.6.38-8-generic
menuentry 'Ubuntu, with Linux 2.6.38-8-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
echo 'Loading Linux 2.6.38-8-generic ...'
linux /boot/vmlinuz-2.6.38-8-generic root=UUID=9396f4d4-00eb-4408-b0b6-81d2cabe9bd5 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows Recovery Environment (loader) (on /dev/sda1)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(/dev/sda,msdos1)'
search --no-floppy --fs-uuid --set=root DAA41C49A41C2B11
drivemap -s (hd0) ${root}
chainloader +1
menuentry "Windows 7 (loader) (on /dev/sda2)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(/dev/sda,msdos2)'
search --no-floppy --fs-uuid --set=root 3080CF3280CEFD7A
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
From Konsole:
ubuntu@ubuntu:~$
sda3 is windows 7
load_env
fi
set default="0"
set boot_once=true
fi
fi
set recordfail=1
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set gfxmode=auto
load_video
insmod gfxterm
fi
insmod part_msdos
insmod ext2
set lang=en_GB
insmod gettext
set timeout=-1
else
set timeout=10
fi
clear
fi
else
fi
else
fi
else
fi
else
fi
recordfail
insmod part_msdos
insmod ext2
recordfail
insmod part_msdos
insmod ext2
recordfail
insmod part_msdos
insmod ext2
recordfail
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ntfs
chainloader +1
insmod part_msdos
insmod ntfs
chainloader +1
fi
