Pinning Help....Please
    Because I was running it and had troubles with videos with it.
    https://www.kubuntuforums.net/showth...k-videos/page2
    Let's try again:
    When I asked you to run
    locate firefox-bin
    the output you posted was this:
    greg@greg-OptiPlex-990:~$ locate firefox-bin
    /home/greg/FixingFF/53/firefox/firefox-bin
    /home/greg/FixingFF/55/firefox/firefox-bin
    greg@greg-OptiPlex-990:~$ ^C
    No sign of Firefox 45.
    To be sure, run
    sudo updatedb
    to refresh the database, wait till you get the terminal prompt back and then run
    locate firefox-bin
    again.
    Kubuntu 20.04
      So what does this mean?
      greg@greg-OptiPlex-990:~$ apt policy firefox
      firefox:
      Installed: 45.0.2+build1-0ubuntu1
      Candidate: 45.0.2+build1-0ubuntu1
      Version table:
      *** 45.0.2+build1-0ubuntu1 500
      500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
      100 /var/lib/dpkg/status
      Greg
      W9WD
        firefox:
        Version table:
            500 [URL]http://us.archive.ubuntu.com/ubuntu[/URL] xenial/main amd64 Packages
        Sorry! Looking back I see you posted that already.
        In which case, I'm wondering why the locate command didn't pick it up and why the system hasn't updated it. I'm totally confused now.
        Edit: I just checked and the firefox executable is in /usr/lib/firefox and is just firefox, not firefox-bin. The latter is found only in the version downloaded from mozilla.org. So that explains why the locate command only picked up the two versions in your home folder. However, the mystery of why your system Firefox is still at version 45 still remains.
        Kubuntu 20.04
          If you have Muon package manager (not Discover), you can view different package versions available, and lock a particular one, all from the GUI. Right-click on the package, and you will see the option there
          I can see FF45 in muon.
          Is there a button to push that will allow me to update it (45) from there?
          Greg
          W9WD
