Pinning Help....Please
    Trying to pin my Firefox 55.0b9 version in Kubuntu 16.04 and it would be less scary if someone could check my syntax before I try it.
    This is in reference to the instructions on pinning given in the article HERE
    If I am thinking correctly about this I would just copy and paste each of these 3 steps in to the terminal...yes?
    Step 1
    APT:efault-Release "xenial";
    Step 2
    # official ubuntu sites
    #### testing #########
    deb http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
    #### development #########
    Step 3
    Package: firefox-55.0b9
    Pin: release n=xenial
    Pin-Priority: -10
    Pin-Priority: 900
    Help?
    Thanks
    Greg
    W9WD
    First, please post the output of
    apt policy firefox
    Kubuntu 20.04
      Here you go...but this is very strange.
      I have downloaded FF55 and changed the panel icon so it starts 55 and not 45.
      I guess if I could actually install 55 instead of just starting it, it would show a different result, but I'm not sure how to do that.
      greg@greg-OptiPlex-990:~$ apt policy firefox
      firefox:
      Installed: 45.0.2+build1-0ubuntu1
      Candidate: 45.0.2+build1-0ubuntu1
      Version table:
      *** 45.0.2+build1-0ubuntu1 500
      500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
      100 /var/lib/dpkg/status
      Greg
      W9WD
        AFAICT, pinning will only work for software installed via the system. It probably won't work for software downloaded as a tar file.
        Where did you get Firefox 55 from?
        Kubuntu 20.04
          At one time, when there was some issue with the google-chrome ppa holding up the apt-get update process, I used to prevent google-chrome from updating with
          echo "google-chrome-stable hold" | sudo dpkg --set-selections
          and then to allow it to update, I would run
          echo "google-chrome-stable install" | sudo dpkg --set-selections
          Kubuntu 20.04
            From the mozilla download page
            http://download.cdn.mozilla.net/pub/firefox/releases/
            Now I'm paranoid to do my weekly
            sudo apt-get clean
            sudo apt-get autoremove --purge
            for fear of updating FF to whatever the current version is (58?)
            Greg
            W9WD
              apt-get wont't "see" your Firefox and so running update and dist-upgrade shouldn't affect your Firefox.
              What about Bing's advice?
              FYI, I'm pretty satisfied with Firefox 58.
              Kubuntu 20.04
                I did try that but every time I started FF from my panel it started 45 instead of 55 even though 55 was there.
                I wound up changing some of the entrees on the start icon so it started 55 instead of 45 and it works, but I get the terminal result I pasted from the commend you suggest (45 not 55)
                Greg
                W9WD
                  If you have Muon package manager (not Discover), you can view different package versions available, and lock a particular one, all from the GUI. Right-click on the package, and you will see the option there
                    Please post the output of
                    locate firefox-bin
                    Kubuntu 20.04
                      greg@greg-OptiPlex-990:~$ locate firefox-bin
                      /home/greg/FixingFF/53/firefox/firefox-bin
                      /home/greg/FixingFF/55/firefox/firefox-bin
                      greg@greg-OptiPlex-990:~$ ^C
                      I created a subdirectory that I called FixingFF and put my downloads from mozilla in there and extracted them there.
                      That's where my quick start icons start from... "55" and "53" are different versions of FF
                      Greg
                      W9WD
                        So these are locally installed versions of Firefox. I pretty confident you can't pin them using the link you provided in the first post of this thread.
                        Bing's advice to you which I linked to earlier maybe the only way.
                        Kubuntu 20.04
                          I tried to do what Bing suggested but maybe I screwed it up.
                          It's just that every time I tried to start what I hoped was FF55, 45 would start.
                          Probably those terminal inputs that you suggested told you what is where and what is installed and so on.
                          Wish I knew more about it.
                          Greg
                          W9WD
                            I think that what we're talking about now has nothing to do with pinning as the term is used in Linux.
                            The other point is that you seem to have two versions of Firefox, 53 and 55, but probably just one profile. That can lead to your browser getting a bit confused if you switch between versions.
                            ls ~/.mozilla/firefox
                            will tell you how many profiles are present.
                            Re. version 45, from what you've posted, it doesn't appear to be installed on your system.
                            Kubuntu 20.04
                              Here's the result
                              greg@greg-OptiPlex-990:~$ ls ~/.mozilla/firefox
                              Crash Reports ibf0en2f.default Pending Pings profiles.ini r8uw1dh2.default
                              I have no idea what this means
                              Greg
                              W9WD
