How to use multiple ESPs for dual-booting
    Dual-booting: How to Use Multiple ESPs
    https://www.kubuntuforums.net/showth...040#post376040
    Step-by-step (more or less) for setting up ESPs to install two Linux OSs, each using its own ESP.
    Thanks to Rod Smith (email) for suggestions to make this go smoothly.
    Qqmike;
    Thank your for the work on the linked thread.
    It makes UEFI much less mysterious and maybe even manageable.
    It was Much needed!
      Thanks, TWPonKubuntu. In many ways, UEFI IS simple. The nice thing is that you can work with UEFI at the high level of your OS or a Live CD, using the filesystem(s) and commands you know, plus just a few new commands. And it is all visible to you! Just open /boot/efi/EFI and look inside!
