Rename forum
    Rename forum
    I believe there is a small inconsistency in your forum naming.
    The recently released version of Kubuntu is Kubuntu 9.04 and should be named in the same manner as your other Kubuntu forums :-) It is fine to keep the codename that has been used through the development cycle, but the primary should be the version number as to minimize the confusion for newcomers.
    Not a big issue, just a curious observation.
    Regards,
    Oceanwatcher
    Blog: http://www.wisnaes.com/
    Pictures: http://www.oceanwatcher.com/
    Software tips (in Norwegian): http://www.datahverdag.com/
    Re: Rename forum
    I use the numbers and not the names because they are easier to remember. Especially since they are named after when they came out, so I can predict what the number for the next version is. I know 10.10 will be released October 2010!
    My Local Repository<br />Forums I am active on<br />Please help me with this!!!!!!!!!!!!!!!!!!!!!!
