System Time
    System Time
    Hi!
    I have set the system time, and it works correctly. But thunderbird still messes up all the time information for both outgoing and incoming emails. It's annoying. Any ideas?
    Thanks!
    Memo
    Re: System Time => Solution
    Ok, here's a reply to myself for future reference. I kept on trying to set the clock and lcoal time using KDE's system settings. It correctly updates KDE clock, it was always different from but what I get from the "date" command. So, any software reading the time from the system reads it wrong. I don't know if this is a Kubuntu bug but here's a quick fix:
    sudo ln -s /usr/share/zoneinfo/America/New_York /etc/localtime
    Check /usr/share/zoneinfo/ to find the correct file for the location you're at
    Cheers to all,
    MeMo
