Focal Testing of Kubuntu 20.04 LTS
    Since this is a Focal thread, I noticed a while ago that when I attempted to install "kde-config-systemd" muon wanted to remove the Kubuntu-desktop and systemsettings.
    I rebooted into what was supposed to be a "persistent" focal installation and got:
    Processing triggers for man-db (2.9.0-1) ...
    Processing triggers for libc-bin (2.30-0ubuntu2) ...
    Processing triggers for linux-image-5.3.0-24-generic (5.3.0-24.26) ...
    /etc/kernel/postinst.d/initramfs-tools:
    update-initramfs is disabled since running on read-only media
    kubuntu@kubuntu:~$
    So, probably my stanza for a persistent install is wrong.
      Yes, because it is a dead project that needs removing in debian and Ubuntu, and also supplies files that directly conflict with new systemsettings.
      Until it is removed in Debian and then in Ubuntu, the conflicts has to be there to prevent people installing it.
        mmm... too bad. Back to the cli.
        https://wiki.archlinux.org/index.php...md#Using_units
        But, I have no clue as to how many of those CLI commands actually work, until I happen to need one and try it out.
        The systemd ui was an app that I really appreciated and it is the only GUI which allowed GUI manipulation of services, unit and config files. I controlled my system from the systemd ui. For example, I used it to create an IPv6 tunnel through Hurricane. Easy as pie to set up with the systemd ui. in /systemd/system it put
        he-ipv6.service
        [Unit]
        Description=he.net IPv6 tunnel
        After=network.target
        [Service]
        Type=oneshot
        RemainAfterExit=yes
        ExecStart=/bin/ip tunnel add he-ipv6 mode sit remote w.x.y.z local 192.168.11.100 ttl 255
        ExecStart=/bin/ip link set he-ipv6 up mtu 1480
        ExecStart=/bin/ip addr add 2001:y:z::2 dev he-ipv6
        ExecStart=/bin/ip -6 route add ::/0 dev he-ipv6
        ExecStop=/bin/ip -6 route del ::/0 dev he-ipv6
        ExecStop=/bin/ip link set he-ipv6 down
        ExecStop=/bin/ip tunnel del he-ipv6
        [Install]
        WantedBy=multi-user.target
        That created what appeared to FireFox and Chromium to be a "native" tunnel that made IPv6 the default with a fall-back to IPv4 in less than a second.
        On https://ipv6-test.com/ I got a 20/20 rating.
        Using the systemd ui was certainly easier than using netplan to set up the IPv6 tunnel, or using a script after the desktop displayed, or doing it by hand, all of which I used at one time or another until the systemd script.
        So sad that Ragnar abandon both the KDE project and his systemdgenie project and disappeared in Japan.
          Answering my own dilemma:
          A persistent ISO boot from the Grub2 menu can only occur IF the ISO sees an EXT4 partition or file that contains casper-rw.
          https://help.ubuntu.com/community/Gr...OBoot/Examples
          When you have a partition with the label casper-rw (or a file with the name casper-rw) containing an ext file system, it will be found during boot and serve as container for persistence. In an internal drive (HDD or SSD) ext4 is recommended. Persistence with a partition will work, when booted via grub and an iso file.
          So add the boot option persistent into the 'linux' line:
          Ergo, even it casper-rw existed a persistent ISO boot wouldn't happen because I am using BTRFS, not EXT4.
          Also, for releases 19.10 and later the initrd exists as initrd, not initrd.lz, like in previous releases.
            On a slightly different topic, if you want KDE Frameworks Version 5.65.0, you can get it by adding the ppa
            sudo add-apt-repository ppa:kubuntu-ppa/staging-frameworks
            I haven't had any problems with it and I like the improved graphics. I have yet to checkout how Wayland is progressing as I noticed a few Wayland packages in the updates.
              Fresh Install today's build
              New Kernel From Proposed (88 packages)
              Operating System: Kubuntu 20.04
              KDE Plasma Version: 5.17.4
              KDE Frameworks Version: 5.64.0
              Qt Version: 5.12.5
              Kernel Version: 5.4.0-8-generic
              ls /lib/modules
              5.4.0-8-generic  5.5.0-050500rc1-generic
              With BTRFS partitions, System Settings crashes at Application Style>Gnome/GTK to Windows Decoration>DrKonqi. Not present with Ext4.
              Gufw (19.04.0) generates an error with the taskbar shortcut.
              Unable to run the command specified. The file or folder python3 does not exist
              Must be re-open from the Kmenu. Pin to favorites and then to taskbar works.
                Where are we suppose to post for problems with focal. I just installed on a USB key and I had problem booting. Booted in rescue mode and "apt upgrade" and then could boot in a terminal and graphic could be started with "startx" on command line. I'm not complaining, it's a development version and we are soon in the process. Also I can't set my "online account" there is a message saying "error loading qml file, module org.kde.account not installed".
                Sorry for the noise, but let me know where I should post for the focal fossa version.
                Regards,
                BT
                  Fixed soon I hope: https://launchpad.net/ubuntu/+source....12.0-0ubuntu2
                    Returning to the topic "booting an ISO from the grub menu" I have found that doing so makes it VERY easy to update an ISO to the latest release. After downloading it merely copy it to the location the 40_custom grub entry expects it to be. No need to burn USB sticks or CDROMS.
                    Also, since I am using BTRFS, I store the ISO's in the <FS_ROOT>, along side @ and @home. So, snapshots never contain the ISO's I am testing, as long as I move them and don't copy them. Win-Win!
                      By default, 40_custom doesn't contain anything except:
                      #!/bin/sh
                      exec tail -n +3 $0
                      # This file provides an easy way to add custom menu entries.  Simply type the
                      # menu entries you want to add after this comment.  Be careful not to change
                      # the 'exec tail' line above.
                      So you have to specify, in this file, where you want the downloaded .iso file to reside at.
                        I tried to reproduce your problems, installed onto a btrfs from an iso zsynced today, but could not. The same versions except that the frameworks version is 5.65.0. I last synced a couple of days ago, but still had to download ~200 MB so things seem active.
                        I'm not sure what you mean by that; I didn't get a taskbar shortcut till I put one there myself. I tried various ways to start gufw with no trouble.
                          I use some grub script that makes a submenu of all the isos in my download directory; not even a copy. (A complication is that all the *buntus use the same file name "focal-desktop-amd64.iso" so I set up links into subdirectories.) Though...
                          That's a handy tip, I hadn't thought of that. A directory from the fs root would do. I've been moving them to an old hard drive for that reason, but booting an iso from an SSD is significantly faster. I imagine zsyncing on the SSD to get the latest will be faster too.
                            Nice!
                            Thanks!
                              Trying to get this to work...
                              I make an entry in the 40_custom file in /etc/grub.d/
                              Like this:
                              #!/bin/sh
                              exec tail -n +3 $0
                              menuentry "Kubuntu 20.04 ISO" {
                                   set isofile="/home/not/Downloads/focal-desktop-amd64.iso"
                                   loopback loop (hd2,2)$isofile
                                   linux (loop)/casper/vmlinuz.efi boot=casper iso-scan/filename=$isofile noprompt noeject
                                   initrd (loop)/casper/initrd.lz
                              The ISO is (in Downloads) on sdc2. So hd2,2, right?
                              I update-grub. No mention of 40_custom or Kubuntu 20.04.
                              I check the initrd.lz entry. It's called plain initrd. I amend the entry. Update.grub. No mentions.
                              I groogle around to see if grub has to be specifically instructed to source 40_custom. Everybody and their grannies insist it does not.
                              I check if it's excusable executable. It is.
                              I copy it to /etc/default/grub.d/ because that is where 99_breeze-grub.cfg is and grub sources that.
                              I realise I'm doing something wrong but I can't guess what it is. I ask :·)
                                The way to see if the 40_custom mechanism is working is to look in /boot/grub/grub.cfg. It says don't edit it, but no-one says don't read it. With my 40_custom saying
                                #!/bin/sh
                                exec tail -n +3 $0
                                set isofile="/iso/kubuntu/focal-desktop-amd64.iso"
                                loopback loop (hd1,6)$isofile
                                linux (loop)/casper/vmlinuz boot=casper iso-scan/filename=$isofile noprompt noeject
                                after sudo update-grub, near the end of /boot/grub/grub.cfg I see
                                ### BEGIN /etc/grub.d/40_custom ###
                                ### END /etc/grub.d/40_custom ###
                                and it works. Note that it says "vmlinuz" not "vmlinuz.efi".
                                BTW, using fixed device numbering will likely bite back one day. I suggest setting simple, meaningful labels on your partitions (using, f.ex. "KDE Partition Manager"). The partition in my example is called "iso", and the loopback line becomes
                                search --no-floppy --set=root --label "iso"
                                loopback loop ($root)$isofile
                                <stuck record mode>Of course, IMO these /etc/grub.d scripts are a mess and far more trouble than they're worth. IMO it's much easier to just edit a simple grub.cfg yourself. The trickiest part is stopping all those over-clever scripts from messing with my simple set up.</stuck...>
