Adept Question
    Adept Question
    Greetings
    I have a slight issue with Adept and mplayer (as well as the firefox plugin to play videos). The initial install was fine, so I thought. When I tried to watch a video (a movie trailer from quicktime), it looked like it was going to work, it was buffering.
    The problem is, it got to 99% and just hung there. It did not lock Firefox up or anything, just never played the video.
    When I went into Adept and looked at the package, it said BREAK in red. So I uninstalled it meaning to re install it.
    It showed up on my list as uninstalled but when I tried to select it for install, the button that says "Apply Changes" would not highlight.
    So, my long winded question is, is there a trick to getting it to install this package again? It is driving me nuts.
    Thanks
    Chris
    Re: Adept Question
    what does the konsole command:
    sudo apt-get install -fs
    tell you?
    <br /><br />*temp. hiatus from forums due to comp + net broken* :&#039;(
