Tv card
    Tv card
    Not sure where to put this. I have a PC-150U tv tuner card from kworld. shown in Trusty Tahr as saa7131/saa7133/saa7135 video broadcast decoder. Not having much luck getting it to work. In win7 it has dual tuners (atsc/analog) and fm radio. H ave tried a few tv tuners shown in Muon. If anyone has gotten one of these cards to work, some direction would be much appreciated.
    Thanks
    chances are you device is not reporting its model fully try loading the saa driver with card=# after it . for instance my card works correctly if i use card=42. also the program tvtime is highly recommended as it very easy to use for testing the tuner. good luck .
    how to:
    first you need to unload the current driver. it would help if we knew exactly what saa driver was being used. use
    lsmod | grep saa
    to find out. in my case its the saa7134 driver and it also loads a sound driver saa7134_alsa both need to be removed.
    sudo rmmod saa7134_alsa
    then
    sudo rmmod saa7134
    now you want to load the driver back up with a manual card selection use (this should work for your card)
    sudo modprobe saa7134 card=189
    your model seams to be #189 if you dont wish to read the list below.
    if you check your dmesg you might see this
    chris@void:~$ dmesg | grep saa
    [ 20.518937] saa7130/34: v4l2 driver version 0, 2, 17 loaded
    [ 20.519062] saa7130[0]: found at 0000:01:06.0, rev: 1, irq: 21, latency: 64, mmio: 0xfbcffc00
    [ 20.519068] saa7134: Board is currently unknown. You might try to use the card=<nr>
    [ 20.519068] saa7134: insmod option to specify which board do you have, but this is
    [ 20.519068] saa7134: somewhat risky, as might damage your card. It is better to ask
    [ 20.519068] saa7134: for support at linux-media@vger.kernel.org.
    [ 20.519068] saa7134: The supported cards are:
    [ 20.519071] saa7134: card=0 -> UNKNOWN/GENERIC
    [ 20.519073] saa7134: card=1 -> Proteus Pro [philips reference design] 1131:2001 1131:2001
    [ 20.519083] saa7134: card=2 -> LifeView FlyVIDEO3000 5168:0138 4e42:0138
    [ 20.519086] saa7134: card=3 -> LifeView/Typhoon FlyVIDEO2000 5168:0138 4e42:0138
    [ 20.519088] saa7134: card=4 -> EMPRESS 1131:6752
    [ 20.519090] saa7134: card=5 -> SKNet Monster TV 1131:4e85
    [ 20.519092] saa7134: card=6 -> Tevion MD 9717
    [ 20.519093] saa7134: card=7 -> KNC One TV-Station RDS / Typhoon TV Tune 1131:fe01 1894:fe01
    [ 20.519096] saa7134: card=8 -> Terratec Cinergy 400 TV 153b:1142
    [ 20.519098] saa7134: card=9 -> Medion 5044
    [ 20.519099] saa7134: card=10 -> Kworld/KuroutoShikou SAA7130-TVPCI
    [ 20.519100] saa7134: card=11 -> Terratec Cinergy 600 TV 153b:1143
    [ 20.519102] saa7134: card=12 -> Medion 7134 16be:0003 16be:5000
    [ 20.519104] saa7134: card=13 -> Typhoon TV+Radio 90031
    [ 20.519106] saa7134: card=14 -> ELSA EX-VISION 300TV 1048:226b
    [ 20.519108] saa7134: card=15 -> ELSA EX-VISION 500TV 1048:226a
    [ 20.519110] saa7134: card=16 -> ASUS TV-FM 7134 1043:4842 1043:4830 1043:4840
    [ 20.519112] saa7134: card=17 -> AOPEN VA1000 POWER 1131:7133
    [ 20.519114] saa7134: card=18 -> BMK MPEX No Tuner
    [ 20.519115] saa7134: card=19 -> Compro VideoMate TV 185b:c100
    [ 20.519117] saa7134: card=20 -> Matrox CronosPlus 102b:48d0
    [ 20.519119] saa7134: card=21 -> 10MOONS PCI TV CAPTURE CARD 1131:2001
    [ 20.519121] saa7134: card=22 -> AverMedia M156 / Medion 2819 1461:a70b
    [ 20.519123] saa7134: card=23 -> BMK MPEX Tuner
    [ 20.519124] saa7134: card=24 -> KNC One TV-Station DVR 1894:a006
    [ 20.519126] saa7134: card=25 -> ASUS TV-FM 7133 1043:4843
    [ 20.519128] saa7134: card=26 -> Pinnacle PCTV Stereo (saa7134) 11bd:002b
    [ 20.519129] saa7134: card=27 -> Manli MuchTV M-TV002
    [ 20.519131] saa7134: card=28 -> Manli MuchTV M-TV001
    [ 20.519132] saa7134: card=29 -> Nagase Sangyo TransGear 3000TV 1461:050c
    [ 20.519134] saa7134: card=30 -> Elitegroup ECS TVP3XP FM1216 Tuner Card( 1019:4cb4
    [ 20.519136] saa7134: card=31 -> Elitegroup ECS TVP3XP FM1236 Tuner Card 1019:4cb5
    [ 20.519138] saa7134: card=32 -> AVACS SmartTV
    [ 20.519139] saa7134: card=33 -> AVerMedia DVD EZMaker 1461:10ff
    [ 20.519141] saa7134: card=34 -> Noval Prime TV 7133
    [ 20.519143] saa7134: card=35 -> AverMedia AverTV Studio 305 1461:2115
    [ 20.519144] saa7134: card=36 -> UPMOST PURPLE TV 12ab:0800
    [ 20.519146] saa7134: card=37 -> Items MuchTV Plus / IT-005
    [ 20.519148] saa7134: card=38 -> Terratec Cinergy 200 TV 153b:1152
    [ 20.519149] saa7134: card=39 -> LifeView FlyTV Platinum Mini 5168:0212 4e42:0212 5169:1502
    [ 20.519152] saa7134: card=40 -> Compro VideoMate TV PVR/FM 185b:c100
    [ 20.519154] saa7134: card=41 -> Compro VideoMate TV Gold+ 185b:c100
    [ 20.519156] saa7134: card=42 -> Sabrent SBT-TVFM (saa7130)
    [ 20.519157] saa7134: card=43 -> :Zolid Xpert TV7134
    [ 20.519158] saa7134: card=44 -> Empire PCI TV-Radio LE
    [ 20.519160] saa7134: card=45 -> Avermedia AVerTV Studio 307 1461:9715
    [ 20.519162] saa7134: card=46 -> AVerMedia Cardbus TV/Radio (E500) 1461:d6ee
    [ 20.519164] saa7134: card=47 -> Terratec Cinergy 400 mobile 153b:1162
    [ 20.519165] saa7134: card=48 -> Terratec Cinergy 600 TV MK3 153b:1158
    [ 20.519167] saa7134: card=49 -> Compro VideoMate Gold+ Pal 185b:c200
    [ 20.519169] saa7134: card=50 -> Pinnacle PCTV 300i DVB-T + PAL 11bd:002d
    [ 20.519171] saa7134: card=51 -> ProVideo PV952 1540:9524
    [ 20.519173] saa7134: card=52 -> AverMedia AverTV/305 1461:2108
    [ 20.519174] saa7134: card=53 -> ASUS TV-FM 7135 1043:4845
    [ 20.519176] saa7134: card=54 -> LifeView FlyTV Platinum FM / Gold 5168:0214 5168:5214 1489:0214 5168:0304
    [ 20.519179] saa7134: card=55 -> LifeView FlyDVB-T DUO / MSI TV@nywhere D 5168:0306 4e42:0306
    [ 20.519181] saa7134: card=56 -> Avermedia AVerTV 307 1461:a70a
    [ 20.519183] saa7134: card=57 -> Avermedia AVerTV GO 007 FM 1461:f31f
    [ 20.519185] saa7134: card=58 -> ADS Tech Instant TV (saa7135) 1421:0350 1421:0351 1421:0370 1421:1370
    [ 20.519188] saa7134: card=59 -> Kworld/Tevion V-Stream Xpert TV PVR7134
    [ 20.519189] saa7134: card=60 -> LifeView/Typhoon/Genius FlyDVB-T Duo Car 5168:0502 4e42:0502 1489:0502
    [ 20.519192] saa7134: card=61 -> Philips TOUGH DVB-T reference design 1131:2004
    [ 20.519194] saa7134: card=62 -> Compro VideoMate TV Gold+II
    [ 20.519195] saa7134: card=63 -> Kworld Xpert TV PVR7134
    [ 20.519197] saa7134: card=64 -> FlyTV mini Asus Digimatrix 1043:0210
    [ 20.519198] saa7134: card=65 -> V-Stream Studio TV Terminator
    [ 20.519200] saa7134: card=66 -> Yuan TUN-900 (saa7135)
    [ 20.519201] saa7134: card=67 -> Beholder BeholdTV 409 FM 0000:4091
    [ 20.519203] saa7134: card=68 -> GoTView 7135 PCI 5456:7135
    [ 20.519205] saa7134: card=69 -> Philips EUROPA V3 reference design 1131:2004
    [ 20.519207] saa7134: card=70 -> Compro Videomate DVB-T300 185b:c900
    [ 20.519209] saa7134: card=71 -> Compro Videomate DVB-T200 185b:c901
    [ 20.519210] saa7134: card=72 -> RTD Embedded Technologies VFG7350 1435:7350
    [ 20.519212] saa7134: card=73 -> RTD Embedded Technologies VFG7330 1435:7330
    [ 20.519214] saa7134: card=74 -> LifeView FlyTV Platinum Mini2 14c0:1212
    [ 20.519216] saa7134: card=75 -> AVerMedia AVerTVHD MCE A180 1461:1044
    [ 20.519218] saa7134: card=76 -> SKNet MonsterTV Mobile 1131:4ee9
    [ 20.519219] saa7134: card=77 -> Pinnacle PCTV 40i/50i/110i (saa7133) 11bd:002e
    [ 20.519221] saa7134: card=78 -> ASUSTeK P7131 Dual 1043:4862
    [ 20.519223] saa7134: card=79 -> Sedna/MuchTV PC TV Cardbus TV/Radio (ITO
    [ 20.519224] saa7134: card=80 -> ASUS Digimatrix TV 1043:0210
    [ 20.519226] saa7134: card=81 -> Philips Tiger reference design 1131:2018
    [ 20.519228] saa7134: card=82 -> MSI TV@Anywhere plus 1462:6231 1462:8624
    [ 20.519230] saa7134: card=83 -> Terratec Cinergy 250 PCI TV 153b:1160
    [ 20.519232] saa7134: card=84 -> LifeView FlyDVB Trio 5168:0319
    [ 20.519234] saa7134: card=85 -> AverTV DVB-T 777 1461:2c05 1461:2c05
    [ 20.519236] saa7134: card=86 -> LifeView FlyDVB-T / Genius VideoWonder D 5168:0301 1489:0301
    [ 20.519239] saa7134: card=87 -> ADS Instant TV Duo Cardbus PTV331 0331:1421
    [ 20.519241] saa7134: card=88 -> Tevion/KWorld DVB-T 220RF 17de:7201
    [ 20.519242] saa7134: card=89 -> ELSA EX-VISION 700TV 1048:226c
    [ 20.519244] saa7134: card=90 -> Kworld ATSC110/115 17de:7350 17de:7352
    [ 20.519246] saa7134: card=91 -> AVerMedia A169 B 1461:7360
    [ 20.519248] saa7134: card=92 -> AVerMedia A169 B1 1461:6360
    [ 20.519250] saa7134: card=93 -> Medion 7134 Bridge #2 16be:0005
    [ 20.519252] saa7134: card=94 -> LifeView FlyDVB-T Hybrid Cardbus/MSI TV 5168:3306 5168:3502 5168:3307 4e42:3502
    [ 20.519255] saa7134: card=95 -> LifeView FlyVIDEO3000 (NTSC) 5169:0138
    [ 20.519257] saa7134: card=96 -> Medion Md8800 Quadro 16be:0007 16be:0008 16be:000d
    [ 20.519259] saa7134: card=97 -> LifeView FlyDVB-S /Acorp TV134DS 5168:0300 4e42:0300
    [ 20.519262] saa7134: card=98 -> Proteus Pro 2309 0919:2003
    [ 20.519263] saa7134: card=99 -> AVerMedia TV Hybrid A16AR 1461:2c00
    [ 20.519265] saa7134: card=100 -> Asus Europa2 OEM 1043:4860
    [ 20.519267] saa7134: card=101 -> Pinnacle PCTV 310i 11bd:002f
    [ 20.519269] saa7134: card=102 -> Avermedia AVerTV Studio 507 1461:9715
    [ 20.519271] saa7134: card=103 -> Compro Videomate DVB-T200A
    [ 20.519272] saa7134: card=104 -> Hauppauge WinTV-HVR1110 DVB-T/Hybrid 0070:6700 0070:6701 0070:6702 0070:6703 0070:6704 0070:6705
    [ 20.519276] saa7134: card=105 -> Terratec Cinergy HT PCMCIA 153b:1172
    [ 20.519278] saa7134: card=106 -> Encore ENLTV 1131:2342 1131:2341 3016:2344
    [ 20.519280] saa7134: card=107 -> Encore ENLTV-FM 1131:230f
    [ 20.519282] saa7134: card=108 -> Terratec Cinergy HT PCI 153b:1175
    [ 20.519284] saa7134: card=109 -> Philips Tiger - S Reference design
    [ 20.519285] saa7134: card=110 -> Avermedia M102 1461:f31e
    [ 20.519287] saa7134: card=111 -> ASUS P7131 4871 1043:4871
    [ 20.519289] saa7134: card=112 -> ASUSTeK P7131 Hybrid 1043:4876
    [ 20.519291] saa7134: card=113 -> Elitegroup ECS TVP3XP FM1246 Tuner Card 1019:4cb6
    [ 20.519293] saa7134: card=114 -> KWorld DVB-T 210 17de:7250
    [ 20.519294] saa7134: card=115 -> Sabrent PCMCIA TV-PCB05 0919:2003
    [ 20.519296] saa7134: card=116 -> 10MOONS TM300 TV Card 1131:2304
    [ 20.519298] saa7134: card=117 -> Avermedia Super 007 1461:f01d
    [ 20.519300] saa7134: card=118 -> Beholder BeholdTV 401 0000:4016
    [ 20.519302] saa7134: card=119 -> Beholder BeholdTV 403 0000:4036
    [ 20.519304] saa7134: card=120 -> Beholder BeholdTV 403 FM 0000:4037
    [ 20.519305] saa7134: card=121 -> Beholder BeholdTV 405 0000:4050
    [ 20.519307] saa7134: card=122 -> Beholder BeholdTV 405 FM 0000:4051
    [ 20.519309] saa7134: card=123 -> Beholder BeholdTV 407 0000:4070
    [ 20.519311] saa7134: card=124 -> Beholder BeholdTV 407 FM 0000:4071
    [ 20.519313] saa7134: card=125 -> Beholder BeholdTV 409 0000:4090
    [ 20.519314] saa7134: card=126 -> Beholder BeholdTV 505 FM 5ace:5050
    [ 20.519316] saa7134: card=127 -> Beholder BeholdTV 507 FM / BeholdTV 509 5ace:5070 5ace:5090
    [ 20.519318] saa7134: card=128 -> Beholder BeholdTV Columbus TV/FM 0000:5201
    [ 20.519320] saa7134: card=129 -> Beholder BeholdTV 607 FM 5ace:6070
    [ 20.519322] saa7134: card=130 -> Beholder BeholdTV M6 5ace:6190
    [ 20.519324] saa7134: card=131 -> Twinhan Hybrid DTV-DVB 3056 PCI 1822:0022
    [ 20.519326] saa7134: card=132 -> Genius TVGO AM11MCE
    [ 20.519327] saa7134: card=133 -> NXP Snake DVB-S reference design
    [ 20.519328] saa7134: card=134 -> Medion/Creatix CTX953 Hybrid 16be:0010
    [ 20.519330] saa7134: card=135 -> MSI TV@nywhere A/D v1.1 1462:8625
    [ 20.519332] saa7134: card=136 -> AVerMedia Cardbus TV/Radio (E506R) 1461:f436
    [ 20.519334] saa7134: card=137 -> AVerMedia Hybrid TV/Radio (A16D) 1461:f936
    [ 20.519336] saa7134: card=138 -> Avermedia M115 1461:a836
    [ 20.519338] saa7134: card=139 -> Compro VideoMate T750 185b:c900
    [ 20.519340] saa7134: card=140 -> Avermedia DVB-S Pro A700 1461:a7a1
    [ 20.519341] saa7134: card=141 -> Avermedia DVB-S Hybrid+FM A700 1461:a7a2
    [ 20.519343] saa7134: card=142 -> Beholder BeholdTV H6 5ace:6290
    [ 20.519345] saa7134: card=143 -> Beholder BeholdTV M63 5ace:6191
    [ 20.519347] saa7134: card=144 -> Beholder BeholdTV M6 Extra 5ace:6193
    [ 20.519349] saa7134: card=145 -> AVerMedia MiniPCI DVB-T Hybrid M103 1461:f636 1461:f736
    [ 20.519351] saa7134: card=146 -> ASUSTeK P7131 Analog
    [ 20.519352] saa7134: card=147 -> Asus Tiger 3in1 1043:4878
    [ 20.519354] saa7134: card=148 -> Encore ENLTV-FM v5.3 1a7f:2008
    [ 20.519356] saa7134: card=149 -> Avermedia PCI pure analog (M135A) 1461:f11d
    [ 20.519358] saa7134: card=150 -> Zogis Real Angel 220
    [ 20.519359] saa7134: card=151 -> ADS Tech Instant HDTV 1421:0380
    [ 20.519361] saa7134: card=152 -> Asus Tiger Rev:1.00 1043:4857
    [ 20.519363] saa7134: card=153 -> Kworld Plus TV Analog Lite PCI 17de:7128
    [ 20.519365] saa7134: card=154 -> Avermedia AVerTV GO 007 FM Plus 1461:f31d
    [ 20.519366] saa7134: card=155 -> Hauppauge WinTV-HVR1150 ATSC/QAM-Hybrid 0070:6706 0070:6708
    [ 20.519369] saa7134: card=156 -> Hauppauge WinTV-HVR1120 DVB-T/Hybrid 0070:6707 0070:6709 0070:670a
    [ 20.519371] saa7134: card=157 -> Avermedia AVerTV Studio 507UA 1461:a11b
    [ 20.519373] saa7134: card=158 -> AVerMedia Cardbus TV/Radio (E501R) 1461:b7e9
    [ 20.519375] saa7134: card=159 -> Beholder BeholdTV 505 RDS 0000:505b
    [ 20.519376] saa7134: card=160 -> Beholder BeholdTV 507 RDS 0000:5071
    [ 20.519378] saa7134: card=161 -> Beholder BeholdTV 507 RDS 0000:507b
    [ 20.519380] saa7134: card=162 -> Beholder BeholdTV 607 FM 5ace:6071
    [ 20.519382] saa7134: card=163 -> Beholder BeholdTV 609 FM 5ace:6090
    [ 20.519384] saa7134: card=164 -> Beholder BeholdTV 609 FM 5ace:6091
    [ 20.519386] saa7134: card=165 -> Beholder BeholdTV 607 RDS 5ace:6072
    [ 20.519387] saa7134: card=166 -> Beholder BeholdTV 607 RDS 5ace:6073
    [ 20.519389] saa7134: card=167 -> Beholder BeholdTV 609 RDS 5ace:6092
    [ 20.519391] saa7134: card=168 -> Beholder BeholdTV 609 RDS 5ace:6093
    [ 20.519393] saa7134: card=169 -> Compro VideoMate S350/S300 185b:c900
    [ 20.519395] saa7134: card=170 -> AverMedia AverTV Studio 505 1461:a115
    [ 20.519396] saa7134: card=171 -> Beholder BeholdTV X7 5ace:7595
    [ 20.519398] saa7134: card=172 -> RoverMedia TV Link Pro FM 19d1:0138
    [ 20.519400] saa7134: card=173 -> Zolid Hybrid TV Tuner PCI 1131:2004
    [ 20.519402] saa7134: card=174 -> Asus Europa Hybrid OEM 1043:4847
    [ 20.519404] saa7134: card=175 -> Leadtek Winfast DTV1000S 107d:6655
    [ 20.519405] saa7134: card=176 -> Beholder BeholdTV 505 RDS 0000:5051
    [ 20.519407] saa7134: card=177 -> Hawell HW-404M7
    [ 20.519409] saa7134: card=178 -> Beholder BeholdTV H7 5ace:7190
    [ 20.519410] saa7134: card=179 -> Beholder BeholdTV A7 5ace:7090
    [ 20.519412] saa7134: card=180 -> Avermedia PCI M733A 1461:4155 1461:4255
    [ 20.519414] saa7134: card=181 -> TechoTrend TT-budget T-3000 13c2:2804
    [ 20.519416] saa7134: card=182 -> Kworld PCI SBTVD/ISDB-T Full-Seg Hybrid 17de:b136
    [ 20.519418] saa7134: card=183 -> Compro VideoMate Vista M1F 185b:c900
    [ 20.519420] saa7134: card=184 -> Encore ENLTV-FM 3 1a7f:2108
    [ 20.519422] saa7134: card=185 -> MagicPro ProHDTV Pro2 DMB-TH/Hybrid 17de:d136
    [ 20.519424] saa7134: card=186 -> Beholder BeholdTV 501 5ace:5010
    [ 20.519425] saa7134: card=187 -> Beholder BeholdTV 503 FM 5ace:5030
    [ 20.519427] saa7134: card=188 -> Sensoray 811/911 6000:0811 6000:0911
    [ 20.519429] saa7134: card=189 -> Kworld PC150-U 17de:a134
    [ 20.519431] saa7134: card=190 -> Asus My Cinema PS3-100 1043:48cd
    [ 20.519433] saa7134: card=191 -> Hawell HW-9004V1
    [ 20.519435] saa7134: card=192 -> AverMedia AverTV Satellite Hybrid+FM A70 1461:2055
    you may also need to use the tuner option to use the RF for television (i do not use my rf input if you don't you can ingore its use) it will be similar except you will also put a tuner=# after the card # (saa7134 card=# tuner=#) this is the only tuner list i could find it might be incomplete
    tuner=0 - Temic PAL (4002 FH5)
    tuner=1 - Philips PAL_I (FI1246 and compatibles)
    tuner=2 - Philips NTSC (FI1236,FM1236 and compatibles)
    tuner=3 - Philips (SECAM+PAL_BG) (FI1216MF, FM1216MF, FR1216MF)
    tuner=4 - NoTuner
    tuner=5 - Philips PAL_BG (FI1216 and compatibles)
    tuner=6 - Temic NTSC (4032 FY5)
    tuner=7 - Temic PAL_I (4062 FY5)
    tuner=8 - Temic NTSC (4036 FY5)
    tuner=9 - Alps HSBH1
    tuner=10 - Alps TSBE1
    tuner=11 - Alps TSBB5
    tuner=12 - Alps TSBE5
    tuner=13 - Alps TSBC5
    tuner=14 - Temic PAL_BG (4006FH5)
    tuner=15 - Alps TSCH6
    tuner=16 - Temic PAL_DK (4016 FY5)
    tuner=17 - Philips NTSC_M (MK2)
    tuner=18 - Temic PAL_I (4066 FY5)
    tuner=19 - Temic PAL* auto (4006 FN5)
    tuner=20 - Temic PAL_BG (4009 FR5) or PAL_I (4069 FR5)
    tuner=21 - Temic NTSC (4039 FR5)
    tuner=22 - Temic PAL/SECAM multi (4046 FM5)
    tuner=23 - Philips PAL_DK (FI1256 and compatibles)
    tuner=24 - Philips PAL/SECAM multi (FQ1216ME)
    tuner=25 - LG PAL_I+FM (TAPC-I001D)
    tuner=26 - LG PAL_I (TAPC-I701D)
    tuner=27 - LG NTSC+FM (TPI8NSR01F)
    tuner=28 - LG PAL_BG+FM (TPI8PSB01D)
    tuner=29 - LG PAL_BG (TPI8PSB11D)
    tuner=30 - Temic PAL* auto + FM (4009 FN5)
    tuner=31 - SHARP NTSC_JP (2U5JF5540)
    tuner=32 - Samsung PAL TCPM9091PD27
    tuner=33 - MT20xx universal
    tuner=34 - Temic PAL_BG (4106 FH5)
    tuner=35 - Temic PAL_DK/SECAM_L (4012 FY5)
    tuner=36 - Temic NTSC (4136 FY5)
    tuner=37 - LG PAL (newer TAPC series)
    tuner=38 - Philips PAL/SECAM multi (FM1216ME MK3)
    tuner=39 - LG NTSC (newer TAPC series)
    tuner=40 - HITACHI V7-J180AT
    tuner=41 - Philips PAL_MK (FI1216 MK)
    tuner=42 - Philips 1236D ATSC/NTSC daul in
    tuner=43 - Philips NTSC MK3 (FM1236MK3 or FM1236/F)
    tuner=44 - Philips 4 in 1 (ATI TV Wonder Pro/Conexant)
    tuner=45 - Microtune 4049 FM5
    tuner=46 - Panasonic VP27s/ENGE4324D
    tuner=47 - LG NTSC (TAPE series)
    tuner=48 - Tenna TNF 8831 BGFF)
    tuner=49 - Microtune 4042 FI5 ATSC/NTSC dual in
    tuner=50 - TCL 2002N
    tuner=51 - Philips PAL/SECAM_D (FM 1256 I-H3)
    tuner=52 - Thomson DDT 7610 (ATSC/NTSC)
    tuner=53 - Philips FQ1286
    tuner=54 - tda8290+75
    tuner=55 - TCL 2002MB
    tuner=56 - Philips PAL/SECAM multi (FQ1216AME MK4)
    tuner=57 - Philips FQ1236A MK4
    tuner=58 - Ymec TVision TVF-8531MF/8831MF/8731MF
    tuner=59 - Ymec TVision TVF-5533MF
    tuner=60 - Thomson DDT 7611 (ATSC/NTSC)
    tuner=61 - Tena TNF9533-D/IF/TNF9533-B/DF
    tuner=62 - Philips TEA5767HN FM Radio
    tuner=63 - Philips FMD1216ME MK3 Hybrid Tuner
    tuner=64 - LG TDVS-H062F/TUA6034
    tuner=65 - Ymec TVF66T5-B/DFF
    tuner=66 - LG NTSC (TALN mini series)
    tuner=67 - Philips TD1316 Hybrid Tuner
    tuner=68 - Philips TUV1236D ATSC/NTSC dual in
    tuner=69 - Tena TNF 5335 MF
    each boot you want to use your card you will need to use those steps. unless you create a rule to do this for you. once you find the command that works you can do this
    $ echo 'options saa7134 card=189' | sudo tee /etc/modprobe.d/saa7134.conf
    change the options to match what you put after modprobe when you load the driver.
    (top of thread: thread tools)
