How to display and print all directories and subdirectories?
    I have a directory that has all of my pdf files. Within this directories is several subdirectories also filled with pdf's.
    Is there a way to print out the contents of each directory all at once, so I can copy and paste the results into a document?
    Or just somehow direct the results to a .txt file or something?
    I can display the contents of each directory, but I don't want to have to do it for each directory. I'd prefer to type something at the top and just run through the whole thing.
    l -R --format=single-column  >mydocs.txt
    Edit: maybe easier to copy a single column output.
    Last edited by rms; Mar 09, 2012, 10:27 AM. Reason: It is easier to copy the output t
    Ok, got it: Ashes come from burning.
      Thanks!!
