[solved] Uninstalling gnunet
    I was interested in gnunet and just installed it, blindly to try it out.
    Installed via:
    $ sudo apt-get install gnunet
    Now I can't uninstall it.
    After issuing:
    $ sudo apt-get purge gnunet
    it seemed to get uninstalled (and apt actually thinks that it's gone), but it is still there (files in /usr/bin/gnunet* and god knows, what else .. and where).
    So is the virbr0-interface and a dnsmasq-process .. that caught my eye, first. :\
    $ ps aux | grep dnsmasq
    dnsmasq --strict-order --bind-interfaces --pid-file=/var/run/libvirt/network/default.pid --conf-file= --except-interface lo --listen-address 192.168.122.1 --dhcp-range 192.168.122.2,192.168.122.254 --dhcp-leasefile=/var/lib/libvirt/dnsmasq/default.leases --dhcp-lease-max=253 --dhcp-no-override
    I'm not a newb, but I've never touched dnsmasq or configured network bridges, yet.
    Since this is really annoying:
    Can anyone please help and tell me, what I need to do in order to find everything that has been changed by installing gnunet and to undo these changes?
    Or will I have to learn not to just install packages - trusting, that I will be able to completely uninstall them - the hard way and wipe/reinstall my whole system?
    Thanks in advance
    cefk
    Re: Uninstalling gnunet
    Gnunet
    :~$ apt-cache show gnunet
    Depends: gnunet-client, gnunet-server, gnunet-tools
    Description: secure, trust-based peer-to-peer framework (meta)
     GNUnet is a peer-to-peer framework which focuses on providing security. All
     link-to-link messages in the network are confidential and authenticated. The
     framework provides a transport abstraction layer and can currently encapsulate
     the peer-to-peer traffic in UDP, TCP, or SMTP messages.
     This package is a metapackage depending on gnunet-client, gnunet-server and
     gnunet-tools.
    Homepage: [url]http://www.gnunet.org/[/url]
    MetaPackages
    https://help.ubuntu.com/community/MetaPackages:
    ...These packages do not contain actual software, they simply depend on other packages to be installed...
    Try to remove the gnunet-client, gnunet-server, gnunet-tools.
    Have you tried ?
    - How to Ask a Question on the Internet and Get It Answered
    - How To Ask Questions The Smart Way
      Thank you very much for saving my day
      Everything I've mentioned before is gone, but one: The virbr0 interface ..
      I'll try if a reboot does the trick and then post, if it helped.
      EDIT: The reboot didn't help. virbr0 is still there.
        You probably already done it but maybe,
        sudo apt-get autoremove
        FKA: tanderson
          Yes, I've tried it, but the virbr0-interface is still there.
          But thanks anyway.
            Simulation
            Dependencies: gnunet -> gnunet-client, gnunet-server, gnunet-tools -> More packages
            At here:
            :~$ apt-get install -s gnunet
            NOTE: This is only a simulation!
               apt-get needs root privileges for real execution.
               Keep also in mind that locking is deactivated,
               so don't depend on the relevance to the real current situation!
            Reading package lists... Done
            The following extra packages will be installed:
             gnunet-client gnunet-common gnunet-server gnunet-tools guile-1.8-libs libadns1 libesmtp6 libextractor-plugins
             libextractor1c2a libglade2-0 libmicrohttpd5
            Suggested packages:
             adns-tools libextractor-java python-extractor
             gnunet gnunet-client gnunet-common gnunet-server gnunet-tools guile-1.8-libs libadns1 libesmtp6
             libextractor-plugins libextractor1c2a libglade2-0 libmicrohttpd5
            Logs/Package managers
            The Synaptic and the Muon package managers are keeping history logs or parsing the apt/dpkg log.
            With the Debian based the installed/updated/removed packages are ending to the the dpkg log.
            Checking installed/updated/removed packages from the dpkg log (command line):
            Recent status log:
            grep "status installed" /var/log/dpkg.log
            grep upgrade /var/log/dpkg.log
            grep remove /var/log/dpkg.log
            A bit older dpkg log:
            grep "status installed" /var/log/dpkg.log.1
            grep upgrade /var/log/dpkg.log.1
            grep remove /var/log/dpkg.log.1
            The oldest logs - rotated dpkg logs (packed): dpkg.log.2.gz, dpkg.log.3.gz...
            Testing/experimenting
            Keeping own logs. There is the logsave command:
            :~$ man logsave
            NAME
                logsave - save the output of a command in a logfile
            SYNOPSIS
                logsave [ -asv ] logfile cmd_prog [ ... ]
            DESCRIPTION
                The logsave program will execute cmd_prog with the specified argument(s),
                and save a copy of its output to logfile.
                If the containing directory for logfile does not exist, logsave will
                accumulate the output in memory until it can be
                written out. A copy of the output will also be written to standard output
            logsave testing_something.log sudo apt-get install something
            With the log file it is a bit easier to remove/purge the unwanted packages.
            Have you tried ?
              This does the trick:
              $ sudo apt-get purge dnsmasq*
                Thank you, OneLine!
                I removed the packages your install-simulation showed, too.
                I'll take your advice to heart for future installs (logging).
                Thanks everybody!
