python-twisted-core dependency problems
    Installed Kubuntu 11.04 64bit on a Sony VAIO Laptop.
    Centrino Duo, 1.5Gb Memory.
    All went well till I tried to install "Radio Tray" from the Get-Deb website. The installer stuck at installing python-twisted-core package claiming unrsolvable dependencies. Since then, when installing other items, the installer tries to sort out these dependencies, seemingly.
    I got the following error list via Synaptic Package manager:
    E: python-twisted-core: subprocess installed post-installation script returned error exit status 1
    E: python-twisted-web: dependency problems - leaving unconfigured
    E: ubuntu-sso-client: dependency problems - leaving unconfigured
    E: python-ubuntuone-storageprotocol: dependency problems - leaving unconfigured
    E: python-twisted-names: dependency problems - leaving unconfigured
    E: python-ubuntuone-client: dependency problems - leaving unconfigured
    E: ubuntuone-client: dependency problems - leaving unconfigured
    E: libsyncdaemon-1.0-1: dependency problems - leaving unconfigured
    E: libubuntuone-1.0-1: dependency problems - leaving unconfigured
    E: libubuntuone1.0-cil: dependency problems - leaving unconfigured
    E: banshee-extension-ubuntuonemusicstore: dependency problems - leaving unconfigured
    I can always re-install and avoid installing "Radio Tray", but it would be better if I knew what the problem was and how to fix it.
    Thanks for any help.
    Re: python-twisted-core dependency problems
    First thing to try in a situation like this is:
    Log out of your desktop. When the greeter appears, choose the "console login" option, usually found under the red arrow or shutdown button.
    Log in to the text console, then:
    sudo service kdm stop
    Once kdm stops, then:
    sudo apt-get install -f
    sudo dpkg --configure -a
    sudo apt-get update
    sudo apt-get dist-upgrade
    You might need to repeat this sequence once or twice. Then reboot.
    sudo reboot
    I have python-twisted-core on my system, installed without any problems.
      imo, sometimes packages from getdeb are missing some basic dependencies, or have these dependency issues, or have version mis-matches
      you shouldn't have to log out of KDE to try the steps
      doctordruidphd gave, just start at the "sudo apt-get install -f" and go from there.
      That way, if you get more errors, you can paste them here and may help us get you cleared up easily.
      Also, a url to the package would help as well. their website's search isn't too good :/
        Thanks guys but I get the same errors. I removed Synaptic Package Manager & unselected the get-deb repository before trying the suggested commands.
        This is the output:
        gavin@gavin-VAIO:~$ sudo apt-get install -f
        [sudo] password for gavin:
        Reading package lists... Done
        Building dependency tree
        12 not fully installed or removed.
        After this operation, 0 B of additional disk space will be used.
        Setting up python-twisted-core (10.2.0-1) ...
        Traceback (most recent call last):
        File "/usr/bin/pycompile", line 322, in <module>
        main()
        File "/usr/bin/pycompile", line 299, in main
        options.force, options.optimize, e_patterns)
        File "/usr/bin/pycompile", line 199, in compile
        os.readlink(fn))
        OSError: [Errno 5] Input/output error: '/usr/lib/python2.7/dist-packages/twisted/internet/test/test_posixprocess.py'
        dpkg: error processing python-twisted-core (--configure):
        dpkg: dependency problems prevent configuration of python-twisted-web:
        python-twisted-web depends on python-twisted-core (>= 10.2); however:
        Package python-twisted-core is not configured yet.
        dpkg: error processing python-twisted-web (--configure):
        dpkg: dependency problems prevent configuration of ubuntu-sso-client:
        ubuntu-sso-client depends on python-twisted-core; however:
        ubuntu-sso-client depends on python-twisted-web; however:
        Package python-twisted-web is not configured yet.
        dpkg: error processing ubuntu-sso-client (--configure):
        dpkg: dependency problems prevent configuration of python-ubuntuone-storageprotocol:
        python-ubuntuone-storageprotocol depends on python-twisted-core; however:
        Package python-twistedNo apport report written because the error message indicates it's a follow-up error from a previous failure.
        No apport report written because MaxReports has already been reached
        dpkg: error processing python-ubuntuone-storageprotocol (--configure):
        dpkg: dependency problems prevent configuration of python-twisted-names:
        python-twisted-names depends on python-twisted-core (>= 10.1); however:
        dpkg: error processing python-twisted-names (--configure):
        dpkg: dependency problems prevent configuration of python-ubuntuone-client:
        python-ubuntuone-client depends on python-ubuntuone-storageprotocol (>= 1.6.1); however:
        Package python-ubuntuone-storageprotocol is not configured yet.
        python-ubuntuone-client depends on python-twisted-web; however:
        python-ubuntuone-client depends on python-twisted-names; however:
        Package python-twisted-names is not configured yet.
        dpkg: error processing python-ubuntuone-client (--configure):
        dependency problems - leavingNo apport report written because MaxReports has already been reached
        unconfigured
        dpkg: dependency problems prevent configuration of ubuntuone-client:
        ubuntuone-client depends on python-ubuntuone-client (= 1.6.2-0ubuntu1); however:
        Package python-ubuntuone-client is not configured yet.
        ubuntuone-client depends on ubuntu-sso-client (>= 1.1.8); however:
        Package ubuntu-sso-client is not configured yet.
        dpkg: error processing ubuntuone-client (--configure):
        dpkg: dependency problems prevent configuration of libsyncdaemon-1.0-1:
        libsyncdaemon-1.0-1 depends on ubuntuone-client (>= 1.6.2-0ubuntu1); however:
        Package ubuntuone-client is not configured yet.
        dpkg: error processing libsyncdaemon-1.0-1 (--configure):
        dpkg: dependency problems prevent configuration of ubuntuone-client-gnome:
        ubuntuone-client-gnome depends on libsyncdaemon-1.0-1; however:
        Package libsyncdaemon-1.0-1 is not configured yet.
        ubuntuone-client-gnome depends on ubuntuone-client (= 1.6.2-0ubuntu1); however:
        dpkg: error processing ubuntuone-client-gnome (--configure):
        dpkg: dependency problems prevent configuration of libubuntuone-1.0-1:
        libubuntuone-1.0-1 depends on libsyncdaemon-1.0-1; however:
        libubuntuone-1.0-1 depends on ubuntu-sso-client (>= 0.97.0); however:
        dpkg: error processing libubuntuone-1.0-1 (--configure):
        dpkg: dependency problems prevent configuration of libubuntuone1.0-cil:
        libubuntuone1.0-cil depends on libubuntuone-1.0-1 (>= 0.2.101); however:
        Package libubuntuone-1.0-1 is not configured yet.
        dpkg: error processing libubuntuone1.0-cil (--configure):
        dpkg: dependency problems prevent configuration of banshee-extension-ubuntuonemusicstore:
        banshee-extension-ubuntuonemusicstore depends on libubuntuone1.0-cil (>= 0.10.0); however:
        Package libubuntuone1.0-cil is not configured yet.
        dpkg: error processing banshee-extension-ubuntuonemusicstore (--configure):
        python-twisted-core
        python-twisted-web
        ubuntu-sso-client
        ubuntuone-client
        libsyncdaemon-1.0-1
        libubuntuone-1.0-1
        libubuntuone1.0-cil
        gavin@gavin-VAIO:~$ sudo dpkg --configure -a
        main()
        os.readlink(fn))
        python-twisted-core
        python-twisted-web
        ubuntuone-client
        ubuntu-sso-client
        libubuntuone-1.0-1
        libubuntuone1.0-cil
        libsyncdaemon-1.0-1
        gavin@gavin-VAIO:~$ sudo apt-get update
        Ign http://extras.ubuntu.com natty InRelease
        Hit http://packages.medibuntu.org natty InRelease
        Ign http://gb.archive.ubuntu.com natty InRelease
        Ign http://gb.archive.ubuntu.com natty-updates InRelease
        Ign http://gb.archive.ubuntu.com natty-backports InRelease
        Hit http://extras.ubuntu.com natty Release.gpg
        Hit http://gb.archive.ubuntu.com natty Release.gpg
        Hit http://gb.archive.ubuntu.com natty-updates Release.gpg
        Ign http://security.ubuntu.com natty-security InRelease
        Hit http://gb.archive.ubuntu.com natty-backports Release.gpg
        Hit http://security.ubuntu.com natty-security Release.gpg
        Hit http://packages.medibuntu.org natty/free Sources
        Hit http://extras.ubuntu.com natty/main Sources
        Hit http://extras.ubuntu.com natty/main amd64 Packages
        Ign http://extras.ubuntu.com natty/main TranslationIndex
        Hit http://security.ubuntu.com natty-security/main Sources
        Hit http://packages.medibuntu.org natty/non-free Sources
        Hit http://gb.archive.ubuntu.com natty/main Sources
        Hit http://gb.archive.ubuntu.com natty/restricted Sources
        Hit http://gb.archive.ubuntu.com natty/universe Sources
        Hit http://gb.archive.ubuntu.com natty/multiverse Sources
        Hit http://gb.archive.ubuntu.com natty/main amd64 Packages
        Hit http://security.ubuntu.com natty-security/restricted Sources
        Hit http://security.ubuntu.com natty-security/universe Sources
        Hit http://security.ubuntu.com natty-security/multiverse Sources
        Hit http://security.ubuntu.com natty-security/main amd64 Packages
        Hit http://security.ubuntu.com natty-security/restricted amd64 Packages
        Hit http://gb.archive.ubuntu.com natty/restricted amd64 Packages
        Hit http://gb.archive.ubuntu.com natty/universe amd64 Packages
        Hit http://gb.archive.ubuntu.com natty/multiverse amd64 Packages
        Ign http://gb.archive.ubuntu.com natty/main TranslationIndex
        Hit http://security.ubuntu.com natty-security/universe amd64 Packages
        Hit http://security.ubuntu.com natty-security/multiverse amd64 Packages
        Ign http://security.ubuntu.com natty-security/main TranslationIndex
        Ign http://security.ubuntu.com natty-security/multiverse TranslationIndex
        Ign http://security.ubuntu.com natty-security/restricted TranslationIndex
        Ign http://security.ubuntu.com natty-security/universe TranslationIndex
        Hit http://packages.medibuntu.org natty/free amd64 Packages
        Ign http://gb.archive.ubuntu.com natty/multiverse TranslationIndex
        Ign http://gb.archive.ubuntu.com natty/restricted TranslationIndex
        Ign http://gb.archive.ubuntu.com natty/universe TranslationIndex
        Hit http://gb.archive.ubuntu.com natty-updates/main Sources
        Hit http://gb.archive.ubuntu.com natty-updates/restricted Sources
        Hit http://gb.archive.ubuntu.com natty-updates/universe Sources
        Hit http://gb.archive.ubuntu.com natty-updates/multiverse Sources
        Hit http://gb.archive.ubuntu.com natty-updates/main amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-updates/restricted amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-updates/universe amd64 Packages
        Hit http://packages.medibuntu.org natty/non-free amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-updates/multiverse amd64 Packages
        Ign http://gb.archive.ubuntu.com natty-updates/main TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-updates/multiverse TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-updates/restricted TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-updates/universe TranslationIndex
        Hit http://gb.archive.ubuntu.com natty-backports/main amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-backports/restricted amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-backports/universe amd64 Packages
        Hit http://gb.archive.ubuntu.com natty-backports/multiverse amd64 Packages
        Ign http://gb.archive.ubuntu.com natty-backports/main TranslationIndex
        Ign http://extras.ubuntu.com natty/main Translation-en_GB
        Ign http://packages.medibuntu.org natty/free TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-backports/multiverse TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-backports/restricted TranslationIndex
        Ign http://gb.archive.ubuntu.com natty-backports/universe TranslationIndex
        Hit http://gb.archive.ubuntu.com natty/main Translation-en_GB
        Hit http://gb.archive.ubuntu.com natty/multiverse Translation-en_GB
        Hit http://gb.archive.ubuntu.com natty/restricted Translation-en_GB
        Hit http://gb.archive.ubuntu.com natty/universe Translation-en_GB
        Ign http://packages.medibuntu.org natty/non-free TranslationIndex
        Ign http://security.ubuntu.com natty-security/main Translation-en_GB
        Ign http://security.ubuntu.com natty-security/multiverse Translation-en_GB
        Ign http://security.ubuntu.com natty-security/restricted Translation-en_GB
        Ign http://security.ubuntu.com natty-security/universe Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty/main Translation-en
        Ign http://gb.archive.ubuntu.com natty/multiverse Translation-en
        Ign http://gb.archive.ubuntu.com natty/restricted Translation-en
        Ign http://gb.archive.ubuntu.com natty/universe Translation-en
        Ign http://gb.archive.ubuntu.com natty-updates/main Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-updates/multiverse Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-updates/restricted Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-updates/universe Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-backports/main Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-backports/multiverse Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-backports/restricted Translation-en_GB
        Ign http://gb.archive.ubuntu.com natty-backports/universe Translation-en_GB
        Ign http://packages.medibuntu.org natty/free Translation-en_GB
        Ign http://packages.medibuntu.org natty/non-free Translation-en_GB
        Ign http://archive.canonical.com natty InRelease
        Hit http://archive.canonical.com natty Release.gpg
        Hit http://archive.canonical.com natty/partner Sources
        Hit http://archive.canonical.com natty/partner amd64 Packages
        Ign http://archive.canonical.com natty/partner TranslationIndex
        Ign http://archive.canonical.com natty/partner Translation-en_GB
        gavin@gavin-VAIO:~$ sudo apt-get dist-upgrade
        Calculating upgrade... Done
        Do you want to continue [Y/n]? y
        main()
        os.readlink(fn))
        unconfigured
        python-twisted-core
        python-twisted-web
        ubuntu-sso-client
        ubuntuone-client
        libsyncdaemon-1.0-1
        libubuntuone-1.0-1
        libubuntuone1.0-cil
        The Radio Tray package that started the problem is here:
        http://www.getdeb.net/software/Radio%20Tray
        Thanks again.
          /start-rant
          I used to use getdeb, but my problem with it is there's no apparent way to just download the package and run a trial install of it. That used to be possible, but now it's their way or the highway; I choose the highway. Just my opinion, that for unoffical packages, one should run --dry-run first, for now obvious reasons.
          /end-of-rant
          onward...
          I downloaded it from its sourceforge page:
          greenman@Wolfenstein:~/Downloads$ sudo dpkg -i --dry-run radiotray_0.6.4_all.deb
          Selecting previously deselected package radiotray.
          (Reading database ... 814551 files and directories currently installed.)
          Unpacking radiotray (from radiotray_0.6.4_all.deb) ...
          No obvious errors, so I think the problem is not the radio-tray application, but somewhere in the mess of python program versions.
          Try:
          sudo apt-get clean
          sudo apt-get install --reinstall python-twisted-core
          This will clean out possibly outdated packages from your cache, and reload the necessary ones from the repositories. Even if it doesn't work, it may give a clearer idea of where the problem is.
