synaptic not opening
    In jaunaty kde 3.5 I can get synaptic to open from kmenu, it works fine from terminal and run command. I've double checked the spelling with no change. It works fine on another machine with the same set up.
    Would like also to get cntrl-alt-backspace to restart X with the login in screen, I see that dontzap is installed.
    Can't get no password login to work either.
    Any ideas on these?
    Thanks
    Re: synaptic not opening
    Synaptic
    What do you have at the Kmenu ?
    Ctrl+Alt+Backspace
    Have you executed the "dontzap" (command line tool to set the DontZap option in xorg.conf) ?
    > Topic: Enable the ctrl-alt-backspace combination
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      I have synaptic as the command in kmenu.
      No I can't find the command to do it. Found it here's the link
      http://www.ubuntugeek.com/howto-enab...tu-jaunty.html
      Thanks for the quick reply
