How can I create a package for apt?
    I have been releasing binary versions of my software for the longest time using dated means and would like to start making deb packages for Kubuntu, what would be the easiest route?
    Also can deb packages run custom scripts on install so I can correct paths in the settings files?
    Re: How can I create a package for apt?
    Maybe these links help:
    Packaging Guide
    https://wiki.kubuntu.org/PackagingGu...PackagingGuide
    KubuntuTutorialsDay / Packaging
    https://wiki.kubuntu.org/KubuntuTutorialsDay/Packaging
    MOTU
    https://wiki.ubuntu.com/MOTU
    Debian New Maintainers' Guide
    http://www.debian.org/doc/manuals/ma.../index.en.html
    How to make deb packages
    http://linuxdevices.com/articles/AT8047723203.html
    Debian Library Packaging guide
    http://www.netfort.gr.jp/~dancer/col...pkg-guide.html
    More links in the FAQ: Installing from source
    http://kubuntuforums.net/forums/inde...opic=3085626.0
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      None of those links really have any detailed information, however I managed to piece enough together from them collectively to achieve my goal, thanks.
        can you post back here some steps? I've been wondering the same thing...
        mm0
        Dell Inspiron 1720 Laptop<br />Intel T9300 Core2Duo Processor @ 2.5Ghz<br />4 GB Ram | 1920 X 1200 Resolution<br />2 X 160 GB SATA HD Internal<br />Nvidia GeForce 8600M Graphics Adapter<br />Using Kubuntu 9.10
          First your directory structure needs to be setup based on the root file system, as an example lets say you have a program called helloworld with no extra files, your directory structure may look like this:
          ~/hello
          ~/hello/helloworld
          What you want is
          ~/hello/
          ~/hello/usr/
          ~/hello/usr/bin
          ~/hello/usr/bin/helloworld
          Now create another folder in your projects root folder called DEBIAN (uppercase)
          ~/hello/DEBIAN
          In this folder, you create a few files that provide details to the package manager. The only one needed, however, is the file called control
          Create a file ~/hello/DEBIAN/control
          The contents of the file should look something like this:
          Package: helloworld
          Version: 1.0
          Section: development
          Architecture: i386
          Depends: libwhatever-1.2
          Installed-Size: 1024
          Maintainer: Me! [ [email]me@email.com[/email] ]
          Provides: helloworld
          Description: This is the uber helloworld app
          Note there is a blank line at the end, this is needed.
          You can google more information about the control file for other options like conflicts and suggested packages.
          Then you run the following command
          dpkg -b ~/hello/ hello.deb
          Thats the basics in a nutshell.
          Note that the above is based on you having a Debian based distro like Kubuntu or Ubuntu.
