Trouble with Audio CDs
    I've had trouble with burning Audio CDs for a while. This problem has happened between different releases of kubuntu (may even date back to my mandrake days) and across two different burner drives. The computer can read the disc fine, data discs are beautiful, but I can not burn an audio CD that'll play in a device other than a computer.
    I started off trying to burn with K3B, and then tried also with the trial version of Nero Linux more recently. The only thing I can guess is that there's a problem finalizing the disc, but nothing actually stands out as the reason I can see. Anyone have any ideas?
    Thanks in advance for any help you guys might have to offer.
    Re: Trouble with Audio CDs
    As no one has actually responded to me on this topic, I thought I'd offer some more information. Hopefully someone will have some idea.
    I'm pretty sure it's not a disc finalization problem at this point, as when I play with cdrecord on the command line, I get this information back:
    goddess@nilpferd:~$ cdrecord dev=1,0,0 -media-info
    Cdrecord-ProDVD-ProBD-Clone 2.01.01a33 (i686-pc-linux-gnu) Copyright (C) 1995-2007 J�rg Schilling
    scsidev: '1,0,0'
    scsibus: 1 target: 0 lun: 0
    Linux sg driver version: 3.5.34
    Using libscg version 'schily-0.9'.
    Device type  : Removable CD-ROM
    Version    : 5
    Response Format: 2
    Capabilities  :
    Vendor_info  : 'LITE-ON '
    Identifikation : 'DVDRW LH-20A1H '
    Revision    : 'LL07'
    Device seems to be: Generic mmc2 DVD-R/DVD-RW/DVD-RAM.
    Using generic SCSI-3/mmc  CD-R/CD-RW driver (mmc_cdr).
    Driver flags  : MMC-3 SWABAUDIO BURNFREE FORCESPEED
    Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R LAYER_JUMP
    Mounted media class:   CD
    Mounted media type:    CD-R
    Disk Is not erasable
    data type:        standard
    disk status:       complete
    session status:      complete
    BG format status:     none
    first track:       1
    number of sessions:    1
    first track in last sess: 1
    last track in last sess: 13
    Disk Is not unrestricted
    Disk type: CD-DA or CD-ROM
    last start of lead in: 716730
    last start of lead out: 1166730
    Track Sess Type  Start Addr End Addr  Size
      1   1 Audio 0     20154   20155
      2   1 Audio 20155   38612   18458
      3   1 Audio 38613   59327   20715
      4   1 Audio 59328   80246   20919
      5   1 Audio 80247   118460   38214
      6   1 Audio 118461   139855   21395
      7   1 Audio 139856   159968   20113
      8   1 Audio 159969   182335   22367
      9   1 Audio 182336   227497   45162
      10   1 Audio 227498   245395   17898
      11   1 Audio 245396   270753   25358
      12   1 Audio 270754   289064   18311
      13   1 Audio 289065   311478   22414
    Last session start address:     0
    Last session leadout start address: 311479
    Any thoughts? I also have two more failed discs I can put in and get this information for if that'll help any. I'm also planning on some manual burning via cdrecord to see if that works also, but I don't have time to attempt that now.
