Need help with Splashy
    Hi all,
    Im having problems with splashy. It only gives me black screen from grub -> login, no error messages.
    So, I did the following:
    -uninstall usplash
    -install both splashy and splashy themes
    -tweak menu.ist, added vga=791 splash to the kernel line
    -ran splashy_config -s fingerprint (said everything ok)
    Still, I get nothing but black screen >
    although when I run command splashy test on konsole, it says "Splashy ERROR: Couldn't splashy_start_splashy(). Error -2"
    Im using kubuntu 7.10.
    Any help would be appreciated
