Linux DVR using Kubuntu? .....
    Is there any way to set this up on our computer? I own a huppage video card... is there any program (free) that will allow you to save video from cable stream to files on your computer? I would like to eventually burn the files to DVD's for personal use only.
    Re: Linux DVR using Kubuntu? .....
    I believe you are looking for MythTV, looks like you can get it with apt-get/adept (sudo apt-get install mythtv). Here is a page describing installation/setup in a bit more detail...
      Yes, MythTV is highly recommended. I have a Hauppauge Nova-T with Myth, and I couldn't do without it.
