dbms and adept manager questions
    Hi all. I'm a new Linux user running Kubuntu 7.04. So far the experience has been great but I have a few questions. I'd like to run a dbms system with support for SQL (I'm assuming they all do but ya never know.). I've seen some in adept however I never know what to download. If I select an item will adept automatically download the supporting files? Also, can anyone tell me how to enable multiverse support in adept? Thanks in advance for the help.
    Re: dbms and adept manager questions
    Adept will take care of any dependencies. To enable extra repos open adept and in the top left under adept you will see manage repositories, When it opens just check what you need then close and fetch updates.
    eriefisher
    ~$sudo make me a sandwich
      Kool. Looks like I already had multiverse enabled but I didn't see anything at first. Thanks for your help.
