cnr in kubuntu?
    cnr in kubuntu?
    has anyone ever tried cnr (cnr.com)
    in kubuntu?
    just browsing there i see a huge list of software to download (even more then the respiratory+
    and the site says it works with ubuntu so it should also work with kubuntu
    anyone tried it? if so what do you got to say about it?
    Re: cnr in kubuntu?
    I've never used it, but checking it out, it seems to be something like CNET's Download.com, which I used frequently with Windows (CNET's been giving a lot of positive feedback on Ubuntu lately, pretty cool hugh?) Thanks for informing me about CNR.com.
    Asus G1S-X3:
    Intel Core2 Duo T7500, Nvidia GeForce 8600M GT, 4Gb PC2-5300, 320Gb Hitachi 7k320, Linux ( )
      Re: cnr in kubuntu?
      I just got an email from Linspire that they are packing up their CNR warehouse and moving everything over to cnr.com. Details are at http://www.linspire.com/oldwarehouse. The first thing I did was go over to www.cnr.com to check it out. It seems like a very good idea for n00bs. If you want a CD burner or MP3 player you just pick and click.
      The next thing I did was search here to see how it would affect a Kubuntu user, and all I found was this old thread.
      Toshiba Satellite 2800 P3M Coppermine @1GHz 256MB RAM GeForce 2 GO with 16MB DDR
        Re: cnr in kubuntu?
        I tried CNR for a few days while trying out Freespire, which comes with CNR.. it was easy and convenient, and I can't remember any problems with it.. but for whatever reason I decided to switch to Kubuntu.. anyway I think it could be a great addition to *buntu, but I would have to try it some more..
        edit: I just tried to install CNR with no success.. the .deb is not for 64bit, and I couldn't get it from the repository either..
          Re: cnr in kubuntu?
          I'll stick with Adept--it's the best, by far.
          Ubuntu 11.04, Kubuntu 11.04, and another TBD
            Re: cnr in kubuntu?
            agreed.. I would only use CNR after failing to find what I'm looking for in Adept and apt-get..
