Howdy my fellow kubuntians.
I am having some trouble compiling konference. I'm almost at the end of 'config.log' req's, but I can't quite get past needing some KDE header files:
...so, I...
...and see it's in the package 'kdelibs4-dev', and as I continue about my merry way installing more and more dev packages...
...hmm...so I need libfam-dev now? ok...
...ooh! Really now? Another one? This is like Sherlock Holmes sleuth type shiznitt...
wtf? Would you like some fries with that screw burger, sir? So, I have to remove my whole KDE desktop because I can't install some KDE header? Who's maintaining these dev packages? I want your head on a silver platter with some fava beans...mmm...fried MOTU...yummy!
configure:30293: checking for KDE configure: 30346: /usr/include/ksharedptr.h configure: 30346: /usr/include/ksharedptr.h configure: 30346: /usr/lib/kde/include/ksharedptr.h ...
skoal@morpheus:///data/distro/ubuntu/dev/konference-0.1 $ apt-file search ksharedptr.h kdelibs4-dev: usr/include/kde/ksharedptr.h
skoal@morpheus:///data/distro/ubuntu/dev/konference-0.1 $ sudo apt-get install kdelibs4-dev Reading package lists... Done Building dependency tree... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. Since you only requested a single operation it is extremely likely that the package is simply not installable and a bug report against that package should be filed. The following information may help to resolve the situation: The following packages have unmet dependencies: kdelibs4-dev: Depends: libfam-dev E: Broken packages
skoal@morpheus:///data/distro/ubuntu/dev/konference-0.1 $ sudo apt-get install libfam-dev Reading package lists... Done Building dependency tree... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. Since you only requested a single operation it is extremely likely that the package is simply not installable and a bug report against that package should be filed. The following information may help to resolve the situation: The following packages have unmet dependencies: libfam-dev: Depends: libfam0 (= 2.7.0-5ubuntu3) E: Broken packages
skoal@morpheus:///data/distro/ubuntu/dev/konference-0.1 $ sudo apt-get install libfam0 Reading package lists... Done Building dependency tree... Done Recommended packages: fam The following packages will be REMOVED: adept akode akregator amarok amarok-arts amarok-engines amarok-gstreamer amarok-xine ark artsbuilder digikam filelight gamin gtk2-engines-gtk-qt gwenview k3b k3blibs kaddressbook kaffeine kaffeine-gstreamer kaffeine-xine kamera kappfinder karm katapult kate kaudiocreator kcalc kcontrol kcron kde-guidance kde-style-lipstik kde-systemsettings kdeadmin-kfile-plugins kdeartwork kdeartwork-style kdeartwork-theme-window kdebase-bin kdebase-kio-plugins kdebluetooth kdegraphics-kfile-plugins kdelibs-bin kdelibs4c2 kdemultimedia-kappfinder-data kdemultimedia-kfile-plugins kdemultimedia-kio-plugins kdenetwork-filesharing kdenetwork-kfile-plugins kdepasswd kdepim-kio-plugins kdepim-kresources kdepim-wizards kdeprint kdesktop kdewebdev kdm kfilereplace kfind kghostview khelpcenter kicker kimagemapeditor kio-apt kio-locate kipi-plugins klaptopdaemon klinkstatus klipper kmail kmenuedit kmilo kmix knetworkconf knotes koffice-data koffice-libs kommander konq-plugins konqueror konqueror-nsplugins konserve konsole kontact konversation kooka kopete korganizer kpdf kpf kppp krdc krfb krita kscd kscreensaver kscreensaver-xsavers ksmserver ksnapshot ksplash ksvg ksysguard ksystemlog kthesaurus ktux kubuntu-default-settings kubuntu-docs kubuntu-konqueror-shortcuts kuser kwalletmanager kwifimanager kwin kxsldbg libcvsservice0 libdbus-qt-1-1c2 libgamin0 libkcal2b libkcddb1 libkdepim1a libkexif1 libkipi0 libkleopatra1 libkmime2 libkonq4 libkpimexchange1 libkpimidentities1 libkscan1 libksieve0 libktnef1 libmimelib1c2 libwvstreams4.0c2-extras openoffice.org2-kde python-kde3 python2.4-gamin python2.4-kde3 quanta sanekonsole wvdial The following NEW packages will be installed: libfam0 0 upgraded, 1 newly installed, 137 to remove and 0 not upgraded. Need to get 25.0kB of archives. After unpacking 389MB disk space will be freed. Do you want to continue [Y/n]? n Abort.
