True Konsole Transparency?
    Does anyone know if it is possible to achieve proper transparency in the Konsole? The built in transparency has x-ray vision through windows which just looks poop. I know that the Gnome Terminal manages it fine with the same nvidia drivers, so it must be possible in the Konsole.
    THanks
    Re: True Konsole Transparency?
    Open a konsole. Select Settings | Schema | Transparent Konsole
    If you like the results, click on Save as Default
      No this is the one that I have but its not true transparency (i.e. it just shows you the wallpaper/desktop and not the actual thing behind it) - I am meaning proper transparency.
        I remember that Beryl WM had an option to turn on real transparency in Konsole. Don't know if Compiz Fusion has it as well.
        In a world without windows and fences who needs Gates?
          Okay. Take a look at this post.
