Fiesty Fawn 64-bit OS
    I'm running fiesty Fawn (64-bit version) on a 64-bit AMD computer. Is there any way I can
    get some 32-bit software to work on this system? I've got two photo packages (proprietary software) for Linux and would like to get them if possible to run on this 64-bit
    machine. . . IS this possible? Or am I out of luck? If I can get them to work I need to know what to install to make this possible.
    Any and all help would be appreciated.
    Thanx
    Rich
    Re: Fiesty Fawn 64-bit OS
    I think you shuold read about linux32 packege. And also you can try to install them with dpkg and --force-architecture option.
      Any of the 22,000+ packages in the repository will work with your 64-bit OS. I think a lot of them are actually 32-bit software apps.
      But the proprietary 32-bit Linux apps would have to be compiled or packaged for your 64-bit kernel.
