Help me find the right cd
    Hi!
    Could someone please help me with the right iso-file to download.
    I tried with a Ubuntu cd but that wouldn't read from the cd-rom.
    Computer:
    Hewlett-Packard Company
    HP Pavilion
    AMD Athlon(tm) 64 X2 Dual
    Core Processor 5000+
    Thanks!
    Re: Help me find the right cd
    What do you mean by wouldn't read ?
      I got some kind of I/O error.
      I got to the menu where I could choose Start or install Ubuntu but after pressed enter it loaded for a while and the I got the error.
        Maybe you should try to burn the cd at lower speed, if it's working, you should try to make a checksum checking.
        Hope it helps
          Yes, burning at a slow speed is a good top.....
          Have you tried the Live CD to see if your system is compatible ?
          & sometimes a cheap media will cause your problem also. I noticed by your post count that you have been using Kubuntu for some time, so are you trying to upgrade to a newer version ?
