I just replaced my /dev/sdb by a new SDD drive. I installed a new Neon system on it. During the install, I was required to furnish not only a partition for /, but a /boot/efi partition in boot mode. So now I have 2 disks, sda and sdb, each of which have an EFI partition and a Neon system. Is this normal and correct?
Problem is, reFind only finds bootable partitions on sda. I can't find anything in the config file which resembles "Look on other volumes". I tried do a workaround by installing refind also on sdb, but now I can't figure out how to boot it.
What to do?
I'm running Plasma version 5.20.0 with Kernel version 5.4.0-48-generic.
Thanks in advance for any ideas.
What to do?
