Massive upgrade to Plasma 5.13.3 today
    Got a pleasant surprise this morning:
    Get:393 http://archive.neon.kde.org/user xenial/main amd64 user-manager amd64 4:5.13.3-0xneon+16.04+xenial+build65 [419 kB]
    Fetched 408 MB in 1min 36s (4,203 kB/s)
    That's nothing.
    If you use Manjaro you'll get a full system upgrade every 2 or 3 weeks with average amount of data around 600MB or sometimes more.
    systemd is not for me. I am a retro Nintendo gamer. consoles I play on are, SNES; N64; GameCube and WII.
    Host: mx Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Trinity R14.0.8 tk: Qt 3.5.0 info: kicker wm: Twin 3.0 base: Debian GNU/Linux 10
      Yeah, it looks like we got Applications and Frameworks updates as well as Plasma
        That's nothing.
        Manjaro is a KDE distro, IIRC, but KDE itself is NOT putting out that many updates that often, and Neon stays on the leading or bleeding edge of KDE, so most of Manjaro's updates have to be non DE stuff. Even the kernel doesn't update that often or that massively. So, what is Manjaro updating?
          "Manjaro is a KDE distro" that implies that it only uses KDE or that KDE is the default desktop. It isn't. Manjaro has three official editions (XFCE, Gnome and KDE) and several community editions. As for what is it updating? Every package that is installed whereby an update is available will be updated.
            https://manjaro.org/category/update/ may offer some pointers.
            Kubuntu 20.04
              Interesting. Updates ranging from 3 days apart to 3 weeks apart, with a variety of apps being updated. When I look at my muon history I see updates nearly every day, with some being 2 days apart. The updates range from being one or two apps to 398 apps, like on the 19th. So, all in all, they look pretty much the same.
              PS- I didn't mean to imply that Manjaro was only KDE. The last I looked at it in 2012 it was offering KDE. Not being an Arch fan I didn't install it.
                I looked through all those updates in Discover and "discovered" that many of them had 18.04 in the name string. Does that mean we are getting an incremental update in bits and pieces? Just curious.
                -=Ken=-
                -=Ken=-
                  A stealth version upgrade? That would be neat if it were so. With Btrfs I could do a 3 minute downgrade if I did not like the upgrade!
                    -=Ken=-
                    Plasma Applications are 18.04. They use a similar versioning scheme to Ubuntu's
                      Only six out of 393 were 18.04
                      From my Muon history:
                        Well, you dispelled that illusion! Thanks! <feigned grin>
                        -=Ken=-
                        -=Ken=-
