Yakuake issue
    Yakuake issue
    Had to totally reinstall KDE neon User Edition after this mornings Plasma 6 massive update to my system. Won't belabor the details, just need help resolving why Yakuake when launched, reports:
    Yakuake was unable to load the Konsole component.
    A Konsole installation is required to use Yakuake.
    Konsole is, of course, installed! What's going on, and how do I fix it?
    Hm, Yakuake 24.02.0 works in my KDE neon test installation (upgraded from Yakuake 23.08.4 and to Plasma 6.0 from Plasma 5.27.10) - the only issue I have is that at the top the upper half of the first line is missing, probably due to the floating Plasma Panel I have there…
    I just additionally tested it in a VM (new KDE neon installation): also no problems with Yakuake 24.02.0 there (except the one I mentioned above).
    Did you try to simply sudo apt reinstall yakuake and/or konsole?
    PS: And you could also sudo apt clean before…
      Did you try to simply sudo apt reinstall yakuake?
      Yes, of course.
      There was a HUGE update this morning; 430+ packages; which I'm pretty sure was the Plasma 6 push. It broke my KDE neon User Edition installation. I created another VM and installed the OS again, using the neon-user-20240122-2226.iso. After that was done, I installed yakuake and that's when I started seeing this issue. I have NOT run apt full-upgrade again. I have simulated it, and pkgProblemResolver identified 6 packages that were problematic. It said it was fixing these by removing specific packages. At the end of the process, there were no ERRORS, at least none reported. But, stuff got removed that shouldn't have been, leaving my system unstable. Some things just didn't work, including normal logging out and/or shutting down. I had to force close the VM. When I rebooted that VM, KDE neon User Edition would not load.
      I'm not going to do the apt full-upgrade until a simulated run doesn't show pkgProblemResolver.
        No idea.
        actually
        But: you need konsole-kpart as well, which is the part that displays the actual terminal in Konsole/Dolphin/Yakuake
        What versions of things do you have?
        $ apt policy yakuake
        yakuake:
        Installed: 24.02.0-0xneon+22.04+jammy+release+build27
        Candidate: 24.02.0-0xneon+22.04+jammy+release+build27
        Version table:
        *** 24.02.0-0xneon+22.04+jammy+release+build27 500
        500 http://archive.neon.kde.org/user jammy/main amd64 Packages
        100 /var/lib/dpkg/status
        23.08.4-0xneon+22.04+jammy+release+build25 500
        23.08.3-0xneon+22.04+jammy+release+build24 500
        23.08.2-0xneon+22.04+jammy+release+build23 500
        21.12.3-1ubuntu1 500
        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        ​Konsole and konsole-kpart should have identical versioning
        $ apt policy konsole
        konsole:
        Installed: 4:24.02.0-0xneon+22.04+jammy+release+build35
        Candidate: 4:24.02.0-0xneon+22.04+jammy+release+build35
        Version table:
        *** 4:24.02.0-0xneon+22.04+jammy+release+build35 500
        4:23.08.4-0xneon+22.04+jammy+release+build33 500
        4:23.08.3-0xneon+22.04+jammy+release+build32 500
        4:23.08.2-0xneon+22.04+jammy+release+build31 500
        4:21.12.3-0ubuntu1 500
        My guess is you didn't get all the updates, so try again, and maybe try and apt -f install to see if that pulls in missing things.
        Also, common to neon only you may want to quickly fix these:
        https://bugs.kde.org/show_bug.cgi?id=481938
        https://bugs.kde.org/show_bug.cgi?id=481945
        Some packaging snafus hgere and there, methinks.
        Plus the missing sound theme, Ocean (ocean-sound-theme)
          That may not happen.
          I often see pkgProblemResolver, but the offered output is usually what I expect.
          What packages?
          I have two upgrades with no major drama. I set aside some work time for this, and was bale to go back to working early
            This is what gets reported:
            Starting pkgProblemResolver with broken count: 6
            Starting 2 pkgProblemResolver with broken count: 6
            Investigating (0) kwrite:amd64 < 4:23.08.4-0xneon+22.04+jammy+release+build29 -> 4:24.02.0-0xneon+22.04+jammy+release+build31 @ii umU Ib >
            Broken kwrite:amd64 Breaks on kate5-data:amd64 < 4:23.08.4-0xneon+22.04+jammy+release+build29 @ii mK >
            Considering kate5-data:amd64 -2 as a solution to kwrite:amd64 102
            Added kate5-data:amd64 to the remove list
            Conflicts//Breaks against version 4:23.08.3-0xneon+22.04+jammy+release+build28 for kate5-data but that is not InstVer, ignoring
            Conflicts//Breaks against version 4:23.08.2-0xneon+22.04+jammy+release+build27 for kate5-data but that is not InstVer, ignoring
            Conflicts//Breaks against version 4:21.12.3-0ubuntu1 for kate5-data but that is not InstVer, ignoring
            Fixing kwrite:amd64 via remove of kate5-data:amd64
            Investigating (0) liblayershellqtinterface6:amd64 < none -> 6.0.0-0xneon+22.04+jammy+release+build34 @un uN Ib >
            Broken liblayershellqtinterface6:amd64 Breaks on liblayershellqtinterface5:amd64 < 5.27.10-0xneon+22.04+jammy+release+build32 @ii mK IPb > (< 6.0.0)
            Considering liblayershellqtinterface5:amd64 -1 as a solution to liblayershellqtinterface6:amd64 35
            Added liblayershellqtinterface5:amd64 to the remove list
            Conflicts//Breaks against version 5.27.9-0xneon+22.04+jammy+release+build31 for liblayershellqtinterface5 but that is not InstVer, ignoring
            Conflicts//Breaks against version 5.27.8-0xneon+22.04+jammy+release+build30 for liblayershellqtinterface5 but that is not InstVer, ignoring
            Conflicts//Breaks against version 5.24.6-0ubuntu0.1 for liblayershellqtinterface5 but that is not InstVer, ignoring
            Conflicts//Breaks against version 5.24.4-0ubuntu1 for liblayershellqtinterface5 but that is not InstVer, ignoring
            Fixing liblayershellqtinterface6:amd64 via remove of liblayershellqtinterface5:amd64
            Investigating (0) kf6-baloowidgets:amd64 < none -> 4:24.02.0-0xneon+22.04+jammy+release+build32 @un uN Ib >
            Broken kf6-baloowidgets:amd64 Breaks on libkf5baloowidgets-bin:amd64 < 4:23.08.4-0xneon+22.04+jammy+release+build25 @ii mK > (< 4:24.02)
            Considering libkf5baloowidgets-bin:amd64 -3 as a solution to kf6-baloowidgets:amd64 4
            Added libkf5baloowidgets-bin:amd64 to the remove list
            Conflicts//Breaks against version 4:21.12.3-0ubuntu1 for libkf5baloowidgets-bin but that is not InstVer, ignoring
            Fixing kf6-baloowidgets:amd64 via remove of libkf5baloowidgets-bin:amd64
            Investigating (0) libappstreamqt5-3:amd64 < none -> 1.0.2-0xneon+22.04+jammy+release+build43 @un uN Ib >
            Broken libappstreamqt5-3:amd64 Breaks on libappstreamqt2:amd64 < 0.16.2-0xneon+22.04+jammy+release+build40 @ii mK >
            Considering libappstreamqt2:amd64 -1 as a solution to libappstreamqt5-3:amd64 3
            Added libappstreamqt2:amd64 to the remove list
            Conflicts//Breaks against version 0.15.2-2 for libappstreamqt2 but that is not InstVer, ignoring
            Fixing libappstreamqt5-3:amd64 via remove of libappstreamqt2:amd64
            Investigating (0) libkimageannotator0:amd64 < 0.5.3-1 @ii mK Ib >
            Broken libkimageannotator0:amd64 Depends on libkimageannotator-common:amd64 < 0.5.3-1 -> 0.7.0-0xneon1+22.04+jammy+release+build3 @ii umU > (= 0.5.3-1)
            Considering libkimageannotator-common:amd64 -1 as a solution to libkimageannotator0:amd64 0
            Added libkimageannotator-common:amd64 to the remove list
            Fixing libkimageannotator0:amd64 via keep of libkimageannotator-common:amd64
            Try to Re-Instate (0) libkimageannotator-common:amd64
            Re-Instated libkimageannotator-common:amd64 (1 vs 1)
            Investigating (1) libkimageannotator0:amd64 < 0.5.3-1 @ii mK Ib >
            Investigating (2) libkimageannotator-qt6-0:amd64 < none -> 0.7.0-0xneon1+22.04+jammy+release+build3 @un uN Ib >
            Broken libkimageannotator-qt6-0:amd64 Conflicts on libkimageannotator-common:amd64 < 0.5.3-1 | 0.7.0-0xneon1+22.04+jammy+release+build3 @ii umH > (< 0.7)
            Considering libkimageannotator-common:amd64 -1 as a solution to libkimageannotator-qt6-0:amd64 1
            Fixing libkimageannotator-qt6-0:amd64 via remove of libkimageannotator-common:amd64
            Investigating (2) libkimageannotator0:amd64 < 0.5.3-1 @ii mK Ib >
            Broken libkimageannotator0:amd64 Depends on libkimageannotator-common:amd64 < 0.5.3-1 | 0.7.0-0xneon1+22.04+jammy+release+build3 @ii umR > (= 0.5.3-1)
            Considering libkimageannotator-common:amd64 1 as a solution to libkimageannotator0:amd64 0
            Removing libkimageannotator0:amd64 rather than change libkimageannotator-common:amd64
            Done
            Entering ResolveByKeep
            I resolved yakuake. Installing konsole-kpart seems to have done the trick.
              Those are what I saw.
              Note:
              Kwrite is now at version 24.02.0, note the conflicts are from the older versions (23.08.4​), not just the Qt/Kf5-to-Qt/Kf6 moves.
              And similar:
                These aren't an issue in my install.
                  OT:
                  Thanks - I just wanted to post these bug reports, because it fixed those issues in both my installations.
