Running icon from panel causes systemd to invoke dolphin first
    On one of my 4 KDE Neon installs whenever I click any icon from any panel Systemd invokes Dolphin with a new tab that states "Loading cancelled" then the application is launched. Here is the syslog showing some warnings from kf.coreaddons and kf.kio.core about finding a file when a folder was expected. If I use the launcher or konsole the application runs fine. It only happens on one installation of 4 so I have borked something and cannot find meanings for warnings via searching. Below is a syslog I get after running nixnote2 and then anydesk. Each time Systemd creates an additional tab in Dolphin. Can anyone help me or point me in the right direction?
    syslog:
    Nov 21 12:27:41 sigma systemd[2508]: Started Dolphin - File Manager.
    Nov 21 12:27:42 sigma dolphin[555272]: kf.coreaddons: KDirWatch: "/home/rob/.local/share/plasma_icons/nixnote2.desktop" is a file. Use addFile!
    Nov 21 12:27:42 sigma dolphin[555272]: libpng warning: iCCP: known incorrect sRGB profile
    Nov 21 12:27:42 sigma dolphin[555272]: kf.kio.core: "/home/rob/.local/share/plasma_icons/nixnote2.desktop is a file, but a folder was expected."
    Nov 21 12:27:42 sigma systemd[2508]: Started NixNote2 - NixNote2.
    Nov 21 12:27:42 sigma plasmashell[555318]: WARN 2022-11-21 12:27:42.703 src/utilities/crossmemorymapper.cpp:57 Shared memory segment failed to allocate, instance key="1256a762-3e5e-4453-ad69-79bf7b90ba5a2"; error=4, "QSharedMemory::create: already exists"
    Nov 21 12:27:42 sigma plasmashell[555318]: INFO 2022-11-21 12:27:42.703 src/main.cpp:225 New shared memory segment could not be created; code=4
    Nov 21 12:27:42 sigma plasmashell[555318]: WARN 2022-11-21 12:27:42.703 src/main.cpp:234 New shared memory segment could not be created; code=4
    Nov 21 12:27:42 sigma plasmashell[555318]: INFO 2022-11-21 12:27:42.703 src/main.cpp:242 Another instance with the same configuration seems to be running running, instance key:"1256a762-3e5e-4453-ad69-79bf7b90ba5a2"
    Nov 21 12:27:42 sigma plasmashell[555318]: INFO 2022-11-21 12:27:42.703 src/main.cpp:269 Another running instance with same account detected - configured action: "SHOW_OTHER" instance key:"1256a762-3e5e-4453-ad69-79bf7b90ba5a2"
    Nov 21 12:27:42 sigma plasmashell[555318]: INFO 2022-11-21 12:27:42.703 src/main.cpp:274 Trying to activate it..
    Nov 21 12:27:43 sigma plasmashell[552848]: INFO 2022-11-21 12:27:43.195 src/nixnote.cpp:2634 SHOW_WINDOW requested by shared memory segment.
    Nov 21 12:27:44 sigma pcloud[2911]: Update for linux-x64-prod-v1.9.9 is not available
    Nov 21 12:27:52 sigma systemd[2508]: app-org.kde.dolphin-ae314bce205b44248b1a35bc41579334.scope: Consumed 1.378s CPU time.
    Nov 21 12:28:26 sigma systemd[2508]: Started Dolphin - File Manager.
    Nov 21 12:28:26 sigma dolphin[555389]: kf.coreaddons: KDirWatch: "/home/rob/.local/share/plasma_icons/anydesk.desktop" is a file. Use addFile!
    Nov 21 12:28:26 sigma dolphin[555389]: kf.coreaddons: KDirWatch: "/home/rob/.local/share/plasma_icons/nixnote2.desktop" is a file. Use addFile!
    Nov 21 12:28:27 sigma dolphin[555389]: libpng warning: iCCP: known incorrect sRGB profile
    Nov 21 12:28:27 sigma dolphin[555389]: kf.kio.core: "/home/rob/.local/share/plasma_icons/nixnote2.desktop is a file, but a folder was expected."
    Nov 21 12:28:27 sigma dolphin[555389]: kf.kio.core: "/home/rob/.local/share/plasma_icons/anydesk.desktop is a file, but a folder was expected."
    Nov 21 12:28:27 sigma systemd[2508]: Started NixNote2 - NixNote2.
    Nov 21 12:28:27 sigma plasmashell[555440]: WARN 2022-11-21 12:28:27.295 src/utilities/crossmemorymapper.cpp:57 Shared memory segment failed to allocate, instance key="1256a762-3e5e-4453-ad69-79bf7b90ba5a2"; error=4, "QSharedMemory::create: already exists"
    Nov 21 12:28:27 sigma plasmashell[555440]: INFO 2022-11-21 12:28:27.295 src/main.cpp:225 New shared memory segment could not be created; code=4
    Nov 21 12:28:27 sigma plasmashell[555440]: WARN 2022-11-21 12:28:27.295 src/main.cpp:234 New shared memory segment could not be created; code=4
    Nov 21 12:28:27 sigma plasmashell[555440]: INFO 2022-11-21 12:28:27.295 src/main.cpp:242 Another instance with the same configuration seems to be running running, instance key:"1256a762-3e5e-4453-ad69-79bf7b90ba5a2"
    Nov 21 12:28:27 sigma plasmashell[555440]: INFO 2022-11-21 12:28:27.296 src/main.cpp:269 Another running instance with same account detected - configured action: "SHOW_OTHER" instance key:"1256a762-3e5e-4453-ad69-79bf7b90ba5a2"
    Nov 21 12:28:27 sigma plasmashell[555440]: INFO 2022-11-21 12:28:27.296 src/main.cpp:274 Trying to activate it..
    Nov 21 12:28:27 sigma anydesk[555446]: Unable to locate theme engine in module_path: "adwaita",
    Nov 21 12:28:27 sigma anydesk[555446]: IA__gtk_widget_show: assertion 'GTK_IS_WIDGET (widget)' failed
    Nov 21 12:28:27 sigma systemd[2508]: Started AnyDesk - AnyDesk.
    Nov 21 12:28:27 sigma anydesk[555446]: gtk_box_pack: assertion 'GTK_IS_WIDGET (child)' failed
    Nov 21 12:28:27 sigma anydesk[555446]: IA__gtk_signal_connect_full: assertion 'GTK_IS_OBJECT (object)' failed
    Nov 21 12:28:27 sigma anydesk[555446]: IA__gtk_widget_set_tooltip_markup: assertion 'GTK_IS_WIDGET (widget)' failed
    Nov 21 12:28:28 sigma plasmashell[552848]: INFO 2022-11-21 12:28:28.195 src/nixnote.cpp:2634 SHOW_WINDOW requested by shared memory segment.
    Nov 21 12:28:37 sigma systemd[2508]: app-org.kde.dolphin-151e7f72c8ec4389bada56a45c34fe2a.scope: Consumed 1.411s CPU time.
    Nov 21 12:30:01 sigma CRON[555585]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
    Nov 21 12:33:04 sigma systemd[1]: Started Run anacron jobs.
    Nov 21 12:33:04 sigma anacron[555758]: Anacron 2.3 started on 2022-11-21
    Nov 21 12:33:04 sigma anacron[555758]: Normal exit (0 jobs run)
    Nov 21 12:33:04 sigma systemd[1]: anacron.service: Deactivated successfully.
    Nov 21 12:34:27 sigma thunderbird[2933]: console.error: mailnews.pop3.144: "NetworkTimeoutError: a Network error occurred"
    Nov 21 12:35:01 sigma CRON[555873]: (rob) CMD (/home/rob/path.sh)
    Nov 21 12:35:01 sigma dbus-daemon[2601]: [session uid=1000 pid=2601] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.7' (uid=1000 pid=2708 comm="/usr/libexec/tracker-miner-fs-3 " label="unconfined")
    Nov 21 12:35:01 sigma systemd[2508]: Starting Tracker metadata extractor...
    Nov 21 12:35:01 sigma dbus-daemon[2601]: [session uid=1000 pid=2601] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
    Nov 21 12:35:01 sigma systemd[2508]: Started Tracker metadata extractor.
    Output from inxi -Fc:
    System: Host: sigma Kernel: 5.15.0-52-generic x86_64 bits: 64 Desktop: KDE Plasma 5.26.3 Distro: KDE neon 22.04 5.26
    Machine: Type: Laptop System: ASUSTeK product: Strix 17 GL703GE v: 1.0 serial: <superuser/root required>
    Mobo: ASUSTeK model: GL703GE v: 1.0 serial: <superuser/root required> UEFI: American Megatrends v: GL703GE.318
    date: 07/19/2019
    Battery: ID-1: BAT1 charge: 34.0 Wh condition: 34.0/64.4 Wh (53%)
    CPU: Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP L2 cache: 9216 KiB
    Speed: 1000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1002 2: 1208 3: 1000 4: 1000 5: 1000 6: 983 7: 900
    8: 1010 9: 900 10: 900 11: 918 12: 916
    Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
    Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia v: 390.154
    Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    Display: x11 server: X.Org 1.21.1.3 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
    resolution: 1920x1080~120Hz
    OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
    Audio: Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
    Sound Server: ALSA v: k5.15.0-52-generic
    Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
    IF: wlo1 state: up mac: 94:b8:6d:2a:05:f8
    Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
    IF: enp2s0 state: down mac: 18:31:bf:97:1b:fd
    Drives: Local Storage: total: 1.14 TiB used: 114.11 GiB (9.8%)
    ID-1: /dev/sda vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
    ID-2: /dev/sdb vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
    Partition: ID-1: / size: 54.70 GiB used: 26.11 GiB (47.7%) fs: ext4 dev: /dev/sda5
    ID-2: /home size: 118.61 GiB used: 80.04 GiB (67.5%) fs: ext4 dev: /dev/sdb2
    Swap: ID-1: swap-1 type: partition size: 13.97 GiB used: 185.2 MiB (1.3%) dev: /dev/sdb3
    Sensors: System Temperatures: cpu: 86.0 C mobo: 27.8 C gpu: nvidia temp: 93 C
    Fan Speeds (RPM): cpu: 0
    Info: Processes: 511 Uptime: 8d 27m Memory: 15.48 GiB used: 8.55 GiB (55.2%) Shell: bash inxi: 3.1.00
    If you create a new, default panel (in plasma you can have several) does the problem occur for it? If it doesn't, you could keep the new one and trash the old.
      Thanks. I tried a new panel a week ago and problem persisted. Tried a new default panel today and removed the old panel and problem persisted. I guess I will reinstall KDE Neon from a live usb w/o reformatting my / and /home directories to see if that fixes the problem.
