How to install XFCE with best rollback options
    I have a perfectly functional Kubuntu Feisty install that I have tweaked to my liking, and would like to install XFCE as a second desktop manager for a test drive. The easiest way that I can see is to install the xubuntu-desktop metapackage. However, I would like to have a 'clean' way to remove it if I change my mind. I have read some posts saying not to use apt-get install, use aptitude install. What's the difference? And are there better options for me?
    Toshiba Satellite 2800 P3M Coppermine @1GHz 256MB RAM GeForce 2 GO with 16MB DDR
    Re: How to install XFCE with best rollback options
    Hmm - Aptitude:
    aptitude is a terminal-based apt frontend with a number of useful features...
    More of the package managers: FAQ: Package Managers
    Hmm#2 - How about:
    logsave + apt/aptitude
    man logsave
    LOGSAVE(8) LOGSAVE(8)
    NAME
    logsave - save the output of a command in a logfile
    SYNOPSIS
    logsave [ -asv ] logfile cmd_prog [ ... ]
    DESCRIPTION
    The logsave program will execute cmd_prog with the specified argu‐
    ment(s), and save a copy of its output to logfile. If the containing
    directory for logfile does not exist, logsave will accumulate the out‐
    put in memory until it can be written out. A copy of the output will
    also be written to standard output.
    sudo logsave Installing.txt apt-get install xubuntu-desktop
    or same with the aptitude.
    => You get a list what to remove...
    Hmm#3 testing:
    sudo logsave Installing.txt apt-get -s install xubuntu-desktop
    man apt-get
    -s, --simulate, --just-print, --dry-run, --recon, --no-act
    No action; perform a simulation of events that would occur but do
    not actually change the system.
    Kubuntu (7.10) Gutsy Gibbon tells:
    Log of apt-get -s install xubuntu-desktop
    Tue Apr 1 19:02:27 2008
    abiword abiword-common abiword-plugins app-install-data-commercial
    apport-gtk apturl brasero displayconfig-gtk doc-base evince-gtk
    example-content feisty-gdm-themes file-roller gamin gcalctool gdebi gdm
    gnome-accessibility-themes gnome-app-install gnome-cards-data gnome-games
    xfce4-weather-plugin xfce4-xkb-plugin xfdesktop4 xfdesktop4-data xfprint4
    xfwm4 xfwm4-themes xscreensaver-gl xubuntu-artwork-usplash
    xubuntu-default-settings xubuntu-desktop xubuntu-docs xvnc4viewer
    0 packages upgraded, 194 newly installed, 1 to remove and 8 not upgraded.
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      Why is there such a difference in what gets installed by the 2 different methods?
      When I try
      apt-get -s intall xubuntu-desktop
      there are 275 packages installed.
      But when I try
      aptitude -s install xubuntu-desktop
      there are 405 packages to install.
      Let me know if you would like me to post the outputs so you can see the package lists.
      __________________
        I found my answer on Ubuntu forums. Aptitude wanted to install recommended packages. The command I needed was
        aptitude -s --without-recommends install xubuntu-desktop
        The full story is at http://ubuntuforums.org/showthread.php?t=743289
          installing xfce on ubuntu 9.10http://freewebcontents.blogspot.com/2009/11/installing-xfce-on-ubuntu-910.html
