Creating space on a small SSD using Win 10 - How?
    My sister has a net book with Windows 10 which has a small 32GB SSD drive. Windows 10, in its f*%$ing wisdom has filled up the SSD with God only knows what, and as a result makes the whole system slow. Thank you Microsoft. Who "developed" Windows 10 to work on a net book with a very small SSD? And why are they still working in the industry?
    Anyway, having not used Windows for years, I tried to remove most of the junk that Windows 10 has filled the SSD with, but the onoy thing I can get rid of are small temporary files which only frees up a very small percentage of stuff.
    I have also disabled Windows 10 hybernation mode as I believe that when it hybernated it "dumped" a load of stuff from RAM on to the SSD, but I cannot find any directories or files relating to the dump so that I can remove it and free up the SSD.
    I think the only way might be to return the net book to its original state, but is there a way of freeing up the SSD without doing that?
    systemd is not for me. I am a retro Nintendo gamer. consoles I play on are, SNES; N64; GameCube and WII.
    Host: mx Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Trinity R14.0.8 tk: Qt 3.5.0 info: kicker wm: Twin 3.0 base: Debian GNU/Linux 10
    I have a win10 tablet thingy I got with the idea of putting Android x86 on it, but the SoC just did not have simple, or even difficult, sound support so I decided to mess with Windows for a spell. 32 gb on Windows anything is not usable, for sure. I will dig up the links I used to shrink Windows down.
    One definitely was to compress the OS, which did not seem to slow things down noticeably on the Atom processor the thing has.
    https://www.windowscentral.com/how-r...tprint-your-pc
    Disabling and deleting restore points can free a lot, but with some risks
    Also, you can delete the recovery partition if it has one,
    https://www.getfilecloud.com/blog/20.../#.W4hi7HX0mzw
    If the system has an sdcard slot, or even a USB stick, you can have Windows use that for all user data and application installs
    https://www.pcworld.com/article/3191...-try-this.html
    Some of these have redundant info, I cannot find the one page that had all these in one spot.
    ooh here's one more
    https://www.laptopmag.com/articles/c...-to-save-space
    I believe doing all of these took mine from around 21+gb down to approx 16, this was on a fresh install, and no restore points, but I disabled them anyway. None of these requires a new install at all, mine was just in that state when I got it.
    Make a recovery stick, too, as this may have any extra software the thing came with, and drivers blah blah. Mine (an Acer) surprisingly came with Firefox.
    Ridiculous, isn't it lol!
      Are you familiar with the KDE tool filelight? (It lets you see what is using filesystem space graphically, with a sunburst pie chart., zooming in on stuff easily.)
      There's a free clone for windows that I found very simple to use, with no installation, called scanner. Standard reservations about downloading windows executables would apply.
