IBM developes memory 100x faster than normal
    http://www.engadget.com/2011/06/30/e...aster-than-fl/
    woodsmoke
    Re: IBM developes memory 100x faster than normal
    Sounds like a good step forward, since it is getting "more reliable" and at the same time allows a "paradigm shift" on data storage. The "is cheap enough to be used in anything from enterprise-level servers all the way down to mobile phones. " part is also very nice.
