No need for Java in LibreOffice?
    Hi all.
    Been playing around with disabling Java in LibreOffice. I used to need Java integration for a couple of reasons:
    Opening password protected documents
    Running and recording Macros. In that respect I have a number of regular contact addresses that I can insert into my correspondence by running a macro.
    With Java disabled, these never used to work. Now they do, although I get an error message first about a JRE being disabled and do I want to enable it. I click no and then it works! A side effect is that the lag that used to be there when clicking the menu on first load has gone
    Wonder whether it's possible (or desirable?) to disable that error message?
