Solved ! How to mark a post as "solved"
    Hi People,
    I am pleased I managed to solve my own problem. How do I add a comment and mark my post as "solved"?
    Thanks for your help
    Re: How to mark a post as "solved"
    Just select the "modify" box next to your first post and edit the title to include "solved". Also if you solved it yourself a brief note as to how you did it may help others so that will be appreciated.
      Go to your original post.
      On the right of your messages you should see a little icon like a piece of paper and pencil. Click that and you can edit.
      Edit the Subject line to something like
      [SOLVED] How to mark a post as "solved"
      "A problem well stated is a problem half solved." --Charles F. Kettering
      "Sometimes the questions are complicated and the answers are simple."--Dr. Seuss
        And put the instructions into your signature for others to see
        Hope it makes sense, anyway.
