reboot required for sound
    roughly 30 percent of the time since installation of kubuntu 24.04 no sound device at boot, reboot required (sometimes multiple, 4 times today) for sound. months now, lots of reports when searching the web. four reboots required today, usually one is sufficient
    And what sound device is it? On what specific computer? This type of problem is very likley and very much hardware/mainboard specific.
    i know you can't post links yet, but....links? How old are they? The same hardware?
      asus laptop about 7 years old, i7 quad 16G by 4G video memory nvidio 10xx
      reboot sometimes 2 or 3 times, sometimes only once, at least once a week since brand new 24.04 kubuntu install
      speaker icon bottom right comes up broken, no audio device
        Not specific enough.
        some info about your audio components will help. This is the easiest way to get this:
        aplay -l
        Are we talking about the laptop audio speakers, or external ones?
        If external and HDMI, what Nvidia driver do you have installed for your 10--something GPU?
        After your third post, you should be able to post links and things.
          Trouble is with internal laptop speakers, no other sound devices available including bluetooth or hdmi.
          1 reboot yesterday, 4 this morning
          more info ...
          from 'about'
          Operating System: Kubuntu 24.04
          KDE Plasma Version: 5.27.12
          KDE Frameworks Version: 5.115.0
          Qt Version: 5.15.13
          Kernel Version: 6.8.0-53-generic (64-bit)
          Graphics Platform: X11
          Processors: 8 × Intel® Core™ i7-7700HQ CPU @ 2.80GHz
          Memory: 15.5 GiB of RAM
          Graphics Processor: Mesa Intel® HD Graphics 630
          Manufacturer: ASUSTeK COMPUTER INC.
          Product Name: GL753VD
          System Version: 1.0​
          from 'pci info center'
          00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
          Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
          Flags: bus master, fast devsel, latency 0, IOMMU group 0
          Capabilities: <access denied>
          Kernel driver in use: skl_uncore
          00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
          Subsystem: ASUSTeK Computer Inc. 6th-10th Gen Core Processor PCIe Controller (x16)
          Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 1
          Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
          I/O behind bridge: e000-efff [size=4K] [16-bit]
          Memory behind bridge: de000000-df0fffff [size=17M] [32-bit]
          Prefetchable memory behind bridge: c0000000-d1ffffff [size=288M] [32-bit]
          Kernel driver in use: pcieport
          00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04) (prog-if 00 [VGA controller])
          DeviceName: Onboard IGD
          Subsystem: ASUSTeK Computer Inc. HD Graphics 630
          Flags: bus master, fast devsel, latency 0, IRQ 139
          Memory at dd000000 (64-bit, non-prefetchable) [size=16M]
          Memory at b0000000 (64-bit, prefetchable) [size=256M]
          I/O ports at f000 [size=64]
          Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
          Kernel driver in use: i915
          Kernel modules: i915
          00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
          Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
          Flags: bus master, fast devsel, latency 0, IRQ 11, IOMMU group 2
          Memory at df430000 (64-bit, non-prefetchable) [size=4K]
          00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
          Flags: bus master, medium devsel, latency 0, IRQ 126, IOMMU group 3
          Memory at df410000 (64-bit, non-prefetchable) [size=64K]
          Kernel driver in use: xhci_hcd
          Kernel modules: xhci_pci
          00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Thermal Subsystem
          Flags: bus master, fast devsel, latency 0, IRQ 18, IOMMU group 3
          Memory at df42f000 (64-bit, non-prefetchable) [size=4K]
          Kernel driver in use: intel_pch_thermal
          Kernel modules: intel_pch_thermal
          00:15.0 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0 (rev 31)
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Serial IO I2C Controller
          Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 4
          Memory at df42e000 (64-bit, non-prefetchable) [size=4K]
          Kernel driver in use: intel-lpss
          Kernel modules: intel_lpss_pci
          00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family MEI Controller
          Flags: bus master, fast devsel, latency 0, IRQ 137, IOMMU group 5
          Memory at df42d000 (64-bit, non-prefetchable) [size=4K]
          Kernel driver in use: mei_me
          Kernel modules: mei_me
          00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31) (prog-if 01 [AHCI 1.0])
          Subsystem: ASUSTeK Computer Inc. HM170/QM170 Chipset SATA Controller [AHCI Mode]
          Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 134, IOMMU group 6
          Memory at df428000 (32-bit, non-prefetchable) [size=8K]
          Memory at df42c000 (32-bit, non-prefetchable) [size=256]
          I/O ports at f090 [size=8]
          I/O ports at f080 [size=4]
          I/O ports at f060 [size=32]
          Memory at df42b000 (32-bit, non-prefetchable) [size=2K]
          Kernel driver in use: ahci
          Kernel modules: ahci
          00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #3 (rev f1) (prog-if 00 [Normal decode])
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family PCI Express Root Port
          Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 7
          Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
          I/O behind bridge: [disabled] [16-bit]
          Memory behind bridge: df300000-df3fffff [size=1M] [32-bit]
          Prefetchable memory behind bridge: [disabled] [64-bit]
          00:1c.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #4 (rev f1) (prog-if 00 [Normal decode])
          Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 8
          Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
          I/O behind bridge: d000-dfff [size=4K] [16-bit]
          Memory behind bridge: df200000-df2fffff [size=1M] [32-bit]
          00:1c.6 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1) (prog-if 00 [Normal decode])
          Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 9
          Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
          Memory behind bridge: df100000-df1fffff [size=1M] [32-bit]
          00:1f.0 ISA bridge: Intel Corporation HM175 Chipset LPC/eSPI Controller (rev 31)
          Subsystem: ASUSTeK Computer Inc. HM175 Chipset LPC/eSPI Controller
          Flags: bus master, medium devsel, latency 0, IOMMU group 10
          00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Power Management Controller
          Flags: bus master, fast devsel, latency 0, IOMMU group 10
          Memory at df424000 (32-bit, non-prefetchable) [size=16K]
          00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31) (prog-if 80)
          Subsystem: ASUSTeK Computer Inc. CM238 HD Audio Controller
          Flags: bus master, fast devsel, latency 32, IRQ 140, IOMMU group 10
          Memory at df420000 (64-bit, non-prefetchable) [size=16K]
          Memory at df400000 (64-bit, non-prefetchable) [size=64K]
          Kernel driver in use: snd_hda_intel
          Kernel modules: snd_hda_intel, snd_soc_avs
          00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
          Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family SMBus
          Flags: medium devsel, IRQ 16, IOMMU group 10
          Memory at df42a000 (64-bit, non-prefetchable) [size=256]
          I/O ports at f040 [size=32]
          Kernel driver in use: i801_smbus
          Kernel modules: i2c_i801
          01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
          Subsystem: ASUSTeK Computer Inc. GP107M [GeForce GTX 1050 Mobile]
          Flags: bus master, fast devsel, latency 0, IRQ 141, IOMMU group 1
          Memory at de000000 (32-bit, non-prefetchable) [size=16M]
          Memory at c0000000 (64-bit, prefetchable) [size=256M]
          Memory at d0000000 (64-bit, prefetchable) [size=32M]
          I/O ports at e000 [size=128]
          Expansion ROM at df000000 [virtual] [disabled] [size=512K]
          Kernel driver in use: nvidia
          Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
          02:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
          Subsystem: Intel Corporation Dual Band Wireless-AC 7265 [Stone Peak 2 AC]
          Flags: bus master, fast devsel, latency 0, IRQ 138, IOMMU group 11
          Memory at df300000 (64-bit, non-prefetchable) [size=8K]
          Kernel driver in use: iwlwifi
          Kernel modules: iwlwifi
          03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
          Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
          Flags: bus master, fast devsel, latency 0, IRQ 19, IOMMU group 12
          I/O ports at d000 [size=256]
          Memory at df204000 (64-bit, non-prefetchable) [size=4K]
          Memory at df200000 (64-bit, non-prefetchable) [size=16K]
          Kernel driver in use: r8169
          Kernel modules: r8169
          04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
          Subsystem: ASUSTeK Computer Inc. RTS5229 PCI Express Card Reader
          Flags: bus master, fast devsel, latency 0, IRQ 135, IOMMU group 13
          Memory at df100000 (32-bit, non-prefetchable) [size=4K]
          Kernel driver in use: rtsx_pci
          Kernel modules: rtsx_pci​
