Problems after 24.04 upgrade
    I have old HP computer with Intel G33 chipset.
    Under 22.04 all worked fine.
    After 24.04 upgrade all text symbols disappear.
    Also I see pink rectangle instead clock on the lock screen.
    Could you help me?
    I suggest this is a driver problem but can't find a solution. I tried oibaf drivers without success.
    Will be helpful if you tell us about your system. Inxi should be installed, so in a konsole type: inxi -F
    Copy/paste the output inside of QUOTE tags. Also, what Themes (Global Theme, Colors, Icons) are you using?
      What are "text symbols" in your view?
        You may only view thumbnails in this gallery. This gallery has 3 photos.
          System:
          Host: dx2400 Kernel: 6.8.0-51-generic arch: x86_64 bits: 64
          Desktop: KDE Plasma v: 5.27.11 Distro: Kubuntu 24.04.1 LTS (Noble Numbat)
          Machine:
          Type: Desktop System: Hewlett-Packard product: HP Compaq dx2400 Microtower
          v: N/A serial: <superuser required>
          Mobo: ASUSTeK model: 2A73h v: 1.01 serial: <superuser required>
          BIOS: American Megatrends v: 5.23 date: 04/21/2008
          CPU:
          Info: dual core Intel Core2 Duo E4600 [MCP] speed (MHz):avg: 2400
          min/max: 1200/2400
          Graphics:
          Device-1: Intel 82G33/G31 Express Integrated Graphics driver: i915 v: kernel
          Device-2: HP HP Webcam HD 2300
          driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB
          Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver:X:
          loaded: intel unloaded: fbdev,modesetting,vesa dri: i915 gpu: i915
          resolution: 1280x1024~60Hz
          API: OpenGL v: 4.5 vendor: mesa v: N/A renderer: i915 (: G33)
          Network:
          Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
          driver: r8169
          Drives:
          Local Storage:total: 606.37 GiB used: 352.37 GiB (58.1%)
          Info:
          Memory:total: 8 GiB available: 7.75 GiB used: 6.63 GiB (85.6%)
          Processes: 238 Uptime: 33m Shell: Bash inxi: 3.3.34
          I use Breeze by default
            Change to the "Breeze" Login Screen theme see if it works. Your selected theme is probably not compatible with the newer plasma 6
              Tried different themes without success
