Headset microphone not detected
    Hello, I'm using this miniPC AM06PRO. I did a clean install of Ubuntu 24.04, but since it didn't work well with my QHD display I installed Kubuntu with "apt get install kubuntu-desktop".
    Most things work fine except that when I try to use the microphone from my Apple wired earpods (3.5mm plug) it is not detected on the system settings. Any solutions for this?
    Thanks!
    When I connect my web cam through USB the microphone that the web cam has is detected correctly, I don't know why the other microphone doesn't.
