Boot Errors
    Boot Errors
    Hi! Just noticed while booting up today some errors, but I don't know how to fix any of them. I executed systemctl --failed as root user, and got this output.
    UNIT LOAD ACTIVE SUB DESCRIPTION
    ● apport-autoreport.service loaded failed failed Process error reports when automatic reporting is enabled
    ● atop.service loaded failed failed Atop advanced performance monitor
    ● clamav-daemon.service loaded failed failed Clam AntiVirus userspace daemon
    ● clamav-freshclam.service loaded failed failed ClamAV virus database updater
    ● [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL] loaded failed failed Postfix Mail Transport Agent (instance -)
    ● virtualbox.service loaded failed failed LSB: VirtualBox Linux kernel module
    Turns out the apport one is just becase i didn't have error reporting activated.
    pursuing the atop failure, i came up with :
    $ systemctl status atop.service
    × atop.service - Atop advanced performance monitor
    Loaded: loaded (/lib/systemd/system/atop.service; enabled; preset: enabled)
    Active: failed (Result: exit-code) since Tue 2023-06-06 15:37:54 EDT; 15s ago
    Docs: man:atop(1)
    Process: 30399 ExecStartPre=/bin/sh -c test -n "$LOGINTERVAL" -a "$LOGINTERVAL" -eq "$LOGINTERVAL" (code=exited, status=0/SUCCESS)
    Process: 30400 ExecStartPre=/bin/sh -c test -n "$LOGGENERATIONS" -a "$LOGGENERATIONS" -eq "$LOGGENERATIONS" (code=exited, status=0/SUCCESS)
    Process: 30401 ExecStart=/bin/sh -c exec /usr/bin/atop ${LOGOPTS} -w "${LOGPATH}/atop_$(date +%Y%m%d)" ${LOGINTERVAL} (code=killed, signal=USR>
    Process: 30402 ExecStartPost=/usr/bin/find ${LOGPATH} -name atop_* -mtime +${LOGGENERATIONS} -exec rm -v {} ; (code=exited, status=1/FAILURE)
    Main PID: 30401 (code=killed, signal=USR2)
    CPU: 13ms
    Jun 06 15:37:54 AmigaBuntu systemd[1]: Starting atop.service - Atop advanced performance monitor...
    Jun 06 15:37:54 AmigaBuntu find[30402]: /usr/bin/find: ‘/var/log/atop’: No such file or directory
    Jun 06 15:37:54 AmigaBuntu systemd[1]: atop.service: Control process exited, code=exited, status=1/FAILURE
    Jun 06 15:37:54 AmigaBuntu systemd[1]: atop.service: Main process exited, code=killed, status=12/USR2
    Jun 06 15:37:54 AmigaBuntu systemd[1]: atop.service: Failed with result 'exit-code'.
    Jun 06 15:37:54 AmigaBuntu systemd[1]: Failed to start atop.service - Atop advanced performance monitor.
    Clamav:
    $ systemctl status clamav-daemon.service
    × clamav-daemon.service - Clam AntiVirus userspace daemon
    Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; preset: enabled)
    Drop-In: /etc/systemd/system/clamav-daemon.service.d
    └─extend.conf
    Active: failed (Result: exit-code) since Tue 2023-06-06 15:41:09 EDT; 1min 53s ago
    Duration: 16ms
    Docs: man:clamd(8)
    man:clamd.conf(5)
    [URL]https://docs.clamav.net/[/URL]
    Process: 38830 ExecStartPre=/bin/mkdir -p /run/clamav (code=exited, status=0/SUCCESS)
    Process: 38831 ExecStartPre=/bin/chown clamav /run/clamav (code=exited, status=0/SUCCESS)
    Process: 38832 ExecStart=/usr/sbin/clamd --foreground=true (code=exited, status=1/FAILURE)
    Main PID: 38832 (code=exited, status=1/FAILURE)
    CPU: 27ms
    Jun 06 15:41:09 AmigaBuntu systemd[1]: Starting clamav-daemon.service - Clam AntiVirus userspace daemon...
    Jun 06 15:41:09 AmigaBuntu systemd[1]: Started clamav-daemon.service - Clam AntiVirus userspace daemon.
    Jun 06 15:41:09 AmigaBuntu clamd[38832]: ERROR: Can't initialize the internal logger
    Jun 06 15:41:09 AmigaBuntu clamd[38832]: ERROR: Can't open /var/log/clamav/clamav.log in append mode (check permissions!).
    Jun 06 15:41:09 AmigaBuntu systemd[1]: clamav-daemon.service: Main process exited, code=exited, status=1/FAILURE
    Jun 06 15:41:09 AmigaBuntu systemd[1]: clamav-daemon.service: Failed with result 'exit-code'.​
    $ systemctl status clamav-freshclam.service
    × clamav-freshclam.service - ClamAV virus database updater
    Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; enabled; preset: enabled)
    Active: failed (Result: exit-code) since Tue 2023-06-06 15:29:53 EDT; 14min ago
    Duration: 27ms
    Docs: man:freshclam(1)
    man:freshclam.conf(5)
    Main PID: 3801 (code=exited, status=2)
    CPU: 25ms
    Jun 06 15:29:53 AmigaBuntu systemd[1]: Started clamav-freshclam.service - ClamAV virus database updater.
    Jun 06 15:29:53 AmigaBuntu freshclam[3801]: ERROR: Problem with internal logger (UpdateLogFile = /var/log/clamav/freshclam.log).
    Jun 06 15:29:53 AmigaBuntu freshclam[3801]: ERROR: initialize: libfreshclam init failed.
    Jun 06 15:29:53 AmigaBuntu freshclam[3801]: ERROR: Initialization error!
    Jun 06 15:29:53 AmigaBuntu freshclam[3801]: ERROR: Can't open /var/log/clamav/freshclam.log in append mode (check permissions!).
    Jun 06 15:29:53 AmigaBuntu systemd[1]: clamav-freshclam.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Jun 06 15:29:53 AmigaBuntu systemd[1]: clamav-freshclam.service: Failed with result 'exit-code'.
    Jun 06 15:36:53 AmigaBuntu systemd[1]: /lib/systemd/system/clamav-freshclam.service:11: Standard output type syslog is obsolete, automatically upd>​
    Postfix:
    $ systemctl status [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL]
    × [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL] - Postfix Mail Transport Agent (instance -)
    Loaded: loaded (/lib/systemd/system/postfix@.service; enabled-runtime; preset: enabled)
    Active: failed (Result: exit-code) since Tue 2023-06-06 15:45:07 EDT; 12s ago
    Docs: man:postfix(1)
    Process: 49130 ExecStartPre=/usr/lib/postfix/configure-instance.sh - (code=exited, status=1/FAILURE)
    CPU: 26ms
    Jun 06 15:45:05 AmigaBuntu systemd[1]: Starting [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL] - Postfix Mail Transport Agent (instance -)...
    Jun 06 15:45:05 AmigaBuntu configure-instance.sh[49132]: postconf: fatal: open /etc/postfix/main.cf: No such file or directory
    Jun 06 15:45:06 AmigaBuntu configure-instance.sh[49134]: postconf: fatal: open /etc/postfix/main.cf: No such file or directory
    Jun 06 15:45:07 AmigaBuntu systemd[1]: [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL]: Control process exited, code=exited, status=1/FAILURE
    Jun 06 15:45:07 AmigaBuntu systemd[1]: [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL]: Failed with result 'exit-code'.
    Jun 06 15:45:07 AmigaBuntu systemd[1]: Failed to start [EMAIL="postfix@-.service"]postfix@-.service[/EMAIL] - Postfix Mail Transport Agent (instance -).
    Virtualbox:
    $ systemctl status virtualbox.service
    virtualbox.service - LSB: VirtualBox Linux kernel module
    Loaded: loaded (/etc/init.d/virtualbox; generated)
    Active: failed (Result: exit-code) since Tue 2023-06-06 15:29:53 EDT; 16min ago
    Docs: man:systemd-sysv-generator(8)
    CPU: 109ms
    Jun 06 15:29:53 AmigaBuntu systemd[1]: Starting virtualbox.service - LSB: VirtualBox Linux kernel module...
    Jun 06 15:29:53 AmigaBuntu virtualbox[3822]: * Loading VirtualBox kernel modules...
    Jun 06 15:29:53 AmigaBuntu virtualbox[3822]: * modprobe vboxdrv failed. Please use 'dmesg' to find out why
    Jun 06 15:29:53 AmigaBuntu virtualbox[3822]: ...fail!
    Jun 06 15:29:53 AmigaBuntu systemd[1]: virtualbox.service: Control process exited, code=exited, status=1/FAILURE
    Jun 06 15:29:53 AmigaBuntu systemd[1]: virtualbox.service: Failed with result 'exit-code'.
    Jun 06 15:29:53 AmigaBuntu systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module.
    I have no idea how to fix this stuff, so thank you for taking a look whoever you may be!
    Some more output:
    $ journalctl -b0 -p 3
    Jun 06 16:21:15 AmigaBuntu systemd-udevd[448]: event_source: Failed to get device name: No such file or directory
    Jun 06 16:21:17 AmigaBuntu bluetoothd[998]: src/plugin.c:plugin_init() Failed to init vcp plugin
    Jun 06 16:21:17 AmigaBuntu bluetoothd[998]: src/plugin.c:plugin_init() Failed to init mcp plugin
    Jun 06 16:21:17 AmigaBuntu bluetoothd[998]: src/plugin.c:plugin_init() Failed to init bap plugin
    Jun 06 16:21:17 AmigaBuntu systemd[1]: Failed to start atop.service - Atop advanced performance monitor.
    Jun 06 16:21:23 AmigaBuntu systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module.
    Jun 06 16:21:25 AmigaBuntu systemd[1]: Failed to start postfix@-.service - Postfix Mail Transport Agent (instance -).
    Jun 06 16:21:28 AmigaBuntu sddm-helper[4055]: gkr-pam: unable to locate daemon control file
    Jun 06 16:21:30 AmigaBuntu systemd[4057]: /run/user/1000/systemd/generator.late/app-startup.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
      IMO, Clamav you don't need unless you're hosting an email server that will have windows users. It probably failed because postfix failed.
      atop is also not a mandatory thing, This gives a clue: Jun 06 15:37:54 AmigaBuntu find[30402]: /usr/bin/find: ‘/var/log/atop’: No such file or directory
      Virtualbox requires a DKMS kernel module to be built. The error here seems clear. Check the output of "dkms status" and make sure the module is built for the kernel you're using.
      apport-autoreport.service is also not needed and has been reported to have a a security flaw.
        Well, I did manage to fix the majority of errors, for example atop needed me to make a directory, and same with clamav. the only one i am currently having trouble with is the virtualbox one. I do have all the appropriate things installed, the issue seems to be that secure boot requires me to sign the vboxdrv kernal module and i am not sure how to go about doing that.
        Thanks for the reply.
        My current issues according to journalctl
        Jun 06 21:53:42 AmigaBuntu systemd-udevd[506]: event_source: Failed to get device name: No such file or directory
        Jun 06 21:53:44 AmigaBuntu bluetoothd[1000]: src/plugin.c:plugin_init() Failed to init vcp plugin
        Jun 06 21:53:44 AmigaBuntu bluetoothd[1000]: src/plugin.c:plugin_init() Failed to init mcp plugin
        Jun 06 21:53:44 AmigaBuntu bluetoothd[1000]: src/plugin.c:plugin_init() Failed to init bap plugin
        Jun 06 21:53:52 AmigaBuntu systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module.
        Jun 06 21:53:56 AmigaBuntu sddm-helper[4266]: gkr-pam: unable to locate daemon control file
        Jun 06 21:53:58 AmigaBuntu systemd[4268]: /run/user/1000/systemd/generator.late/app-startup.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
        Jun 06 21:58:52 AmigaBuntu postfix/local[19992]: error: open database /etc/aliases.db: No such file or directory
        Jun 06 22:00:02 AmigaBuntu systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module.
        Jun 07 08:59:56 AmigaBuntu postfix/local[31356]: error: open database /etc/aliases.db: No such file or directory
        As requested here is my dkms status
        dkms status
        virtualbox/7.0.6, 6.2.0-20-generic, x86_64: installed
        ​Thank you for taking the time to examine and reply.
          Are you dual booting with windows? Try disabling secure boot.
            Or https://askubuntu.com/questions/9149...ng-secure-boot
              Perfect, That did it.Thank you. I'll post again if i need assistance with these other errors.
