Kup backup
    Kup backup
    Dear All,
    I'm deseperatly trying tu backup with Kup.
    I read that some people also have had difficulties.
    I read that the destination folder has to already exist.
    I know that you can use it manually or automatically.
    Anyway the following popup asks me if I want a first backup now, but I have no idea how I can answer it.
    I would be glad to get help.
    I've been using it for a few years now, but never saw missing buttons there.
    Try clicking on the system tray icon, which may show the buttons.
    I can't recall which version of kup you have in 22.04, as I use KDE neon, which usually has had a more current version of it. But I do know in earlier versions some things didn't work correctly until the next login, and the UI could be buggy at times, at least before Plasma 5.27.
      I'm going to guess that the popup window is sizable. Position your mouse cursor on the lower right corner. Doe a double ended arrow present? If it does, right-click and hold and then drag downwards to resize the window to show what you can't see now.
        I don't think it is - it is a standard notification popup. I haven't been able to test it yet, though.
          Thank you very much claydoh and Snowhog for your answers.
          I repeated once more what I did and this time there was the following black window.
          I could click on "Yes".
