Kubuntu 21.10 upgrade
    I have kubuntu 21.04 but i want to upgrade it to the new version. How i can do it without use a usb iso , throug the konsole . Have it a way or not? Thank you for your help and sorry for my english.
    sudo apt upgrade && sudo apt full-uprade
    When that finishes:
    sudo do-release-upgrade
      From https://kubuntu.org/news/kubuntu-21-...ndri-released/ see this link:
      https://help.ubuntu.com/community/Im...grades/Kubuntu
        First, make sure your backups are current, for anything you don't want to lose.
        The easy way... wait and Kubuntu will suggest it to you. That might be a few weeks, it might be today.
        Otherwise, assuming you have a decent internet connection, open a konsole and run
        It will take a while, maybe hours, depending on how much software you've installed.
        BTW, it's not possible to upgrade using a iso, unless you do a reinstall. (Some would recommend that, and it is much faster. If you don't reformat /home you'd keep most of your settings, but you'd have to reinstall any software you've installed.)
