Upgraded 7.10 to 8.04 64 bit Problem with sudo
    Hi
    I have upgraded to 8.04 from 7.10.
    I had a problem booting at the start as my computer crashed during the initial shut down and reboot.
    8.04 did not appear in the Grub boot list. I have got it to boot with the aid of the recovery program and installing Hardy pre-release to hda. My main program is on hdb
    I have the following problem with sudo
    ken@ken-desktop:~$ sudo nano /etc/group-
    sudo: unable to resolve host ken-desktop
    ken@ken-desktop:~$
    I am unable to open anything for the administrator in KDE
    Any help would be appreciated
    Lurch
    Re: Upgraded 7.10 to 8.04 64 bit Problem with sudo
    This seems to be a general problem on upgrading to hardy. It is caused by the /etc/hosts file being written without the hostname. The first line of your /etc/hosts file probably now looks like
    127.0.0.1 localhost
    and you want to replace this with
    127.0.0.1 localhost ken-desktop
    127.0.0.1 ken-desktop
    To do this, you will probably need to login to failsafe mode.
    If this doesn't work I may be able to help; my system was pretty messed up
      Hi Nck
      Thanks for the reply and help.
      It appears to have fixed the sudo problem, time will tell.
      The other problem is when I log in the 7.10 log in screen is still coming up.
      I log in it boots to the desktop flickers blacks out and the 7.10 log in screen appears.
      I log back in and it boots up ok.
      A Grub problem perhaps?
      Lurch
        Haven't seen anything like this, sorry.
          Hi nck
          Thanks for the reply.
          I will keep looking
          Best regards
          Lurch
