help setting up wireless connection!
    I just installed kubuntu as a dual boot with xp. I have a dlink wda-1320 and I can't seem to get it connected. I am new to linux so any advice would be greatly appreciated. I have done a lot of searching but can't seem to find anything. From what I've read my card has the Atheros chipset. Any ideas and what I should do?
    Thanks!
    Re: help setting up wireless connection!
    How to Solve KnetworkManager Wireless Connection Problems may be helpful.
      wow! I edited the etc/network/interface file to
      auto lo
      iface lo inet loopback
      address 127.0.0.1
      netmask 255.0.0.0
      auto eth0
      iface eth0 inet dhcp
      auto eth1
      iface eth1 inet dhcp
      auto eth2
      iface eth2 inet dhcp
      auto wlan0
      iface wlan0 inet dhcp
      auto ath0
      #iface ath0 inet dhcp
      mine looked nothing like that. I rebooted and it is working great now! I am posting this from linux! the only thing I notice is that my signal strength is kinda low and I have a high gain antenna. Anyway, thanks for the help!
        The thanks goes to gilf - he put the HOWTO together. But, you are welcome none the less.
