need sound help
    need sound help
    i cant seem to find any information on getting my sound to work. when i run lspci -v and scroll down and find my sound card this is what i find below
    00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
    Subsystem: Acer Incorporated [ALI] Unknown device 011d
    Flags: bus master, fast devsel, latency 0, IRQ 22
    Memory at f0500000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
    i have looked for alsa drivers, but could not find any for the ich8 chipset. anyone have any ideas?
    Re: need sound help
    Most folks can work their way through this and eventually fix it:
    http://ubuntuforums.org/showthread.php?t=205449
      Re: need sound help
      Probably superflous but mine reads ver similar and i also have no sound:
      Subsystem: Acer Incorporated [ALI] Unknown device 011b
      Flags: bus master, fast devsel, latency 0, IRQ 23
      Capabilities: [50] Power Management version 2
      Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
      Capabilities: [70] Express Unknown type IRQ 0
      Admittedly I am very new to Linux but have gone through that thread 2 and a half times with the first step b eing successful it doesn't leave me many options to try.
      At a loss and becoming somewhat frustrated since i've been almost a month without my music (half the reason i bought this new nb.
      ta
        Re: need sound help
        http://ubuntuforums.org/showthread.php?t=600714&page=11
        Complete all of the steps in section F.
        Mike
        Edit: I corrected the original page.
        http://monte48lowes.blogspot.com
          Re: need sound help
          monte, thank you.
          i am now listening to the cheerful and hopeful sounds of Fionn Regan as i type.
          just a couple of concerns which someone may be able to direct me to do something if need be.
          at step F.4.2 i was told:
          "sudo: /etc/init.d/alsasound: command not found"
          then at another step a bit later:
          * Setting up ALSA...
          * warning: 'alsactl restore' failed with error message 'alsactl: set_control:989: warning: name mismatch (Master Playback Volume/Front Playback Volume) for control #1
          alsactl: set_control:991: warning: index mismatch (0/0) for control #1
          alsactl: set_control:989: warning: name mismatch (Off-hook Switch/Front Playback Switch) for control #2
          alsactl: set_control:991: warning: index mismatch (0/0) for control #2
          alsactl: set_control:1083: bad control.2.value type'...
          amixer: Mixer hw:0 load error: Invalid argument
          etc.
          Then later again (perhaps not surprisingly given the first concern):
          "ALSA driver is already running."
          If there is nothing to worry about, i'd still appreciate someone telling me to put my mind at rest.
          next, the wireless card...
            Re: need sound help
            The first error you incurred is normal. Both commands at F.4 are there to ensure that alsa is completely stopped. The second step may be unnecessary, but I included it since it does not hurt anything to run it.
            Regarding the other error. I am not sure what is causing that to happen. If the only time you encountered that error was during alsa installation and sound is now working correctly, I would disregard it.
            Regarding wireless. What is the 'lspci' output regarding your wireless card?
            Mike
              Re: need sound help
              that was the best answer you could give. thanks mike
              as for the wireless, i thought perhaps i should post it in another thread so...
              http://kubuntuforums.net/forums/inde...opic=3092341.0
              ron
              by the way, not sure if what i've included is or isn't the lspci output
