No wireless connection.. didn't get help by reading forums..
    Well, I don't get it. when the kubuntu 7.10 live cd is in, the wireless works just fine. Installing it, wireless is gone. I have linksys wrt54g router and if my laptop's handbook doesn't lie, then the wireless card or something is intel pro/wireless 2915ABG mini-PCI wireless LAN module.. after installing kubuntu, everything seems just fine. it says something like ethernet is connected, but no wlan0 network connection is found. I don't remember what exactly. what\s funny, few hours ago, when I had kubuntu installed, everything worked. but only for max 10 minutes. it happend twice. I tried in terminal this command "sudo dhclient wlan0". it didn't work. in the end it said something like "sleeping".. but about 30 minutes later, the internet came, and it was this worked-for-10-minutes-thing.. I don\t know anymore what to do. Any ideas ?
    Re: No wireless connection.. didn't get help by reading forums..
    I have a few; let's try this first: open Konsole and run the command
    kdesudo kate /etc/network/interfaces
    Enter your password when prompted and replace the entire content of the file with the following:
    auto eth0
    iface eth0 inet dhcp
    auto eth1
    iface eth1 inet dhcp
    auto eth2
    iface eth2 inet dhcp
    auto wlan0
    iface wlan0 inet dhcp
    auto ath0
    #iface ath0 inet dhcp
    Be sure to leave a blank line at the end of the file, save it and close Kate, logout, press Alt+E to restart the Xserver, and log back in to see if you have a connection.
    Asus G1S-X3:
    Intel Core2 Duo T7500, Nvidia GeForce 8600M GT, 4Gb PC2-5300, 320Gb Hitachi 7k320, Linux ( )
      It didn't work
        this page might have some help.
        http://ubuntuforums.org/showthread.php?t=80786
        FKA: tanderson
          This thread seems to be referring to issues with the S72.
          Didn't offer much help.
          In regards to the post by Integr8r
          I edited that file and no results.
            As this thread was nearly 3 years old, I am sure the info in it is quite outdated.
