Working system and /home
    Hi, how can i add /home directory on the separate partition? Now i have /home one on the system partition. Thanks.
    Re: Working system and /home
    This should get you started:
    http://ubuntu.wordpress.com/2006/01/...own-partition/
    Brought to you by google: www.google.com
    4 GB Ram
    Kubuntu 18.10
      It's a three step process:
      1 .- Create the new partition (you will need to resize another partition or buy a new hard disk)
      2 .- Copy all your data from you home to the new partition
      3 .- Mount your new partition as /home.
      You will probably need some LiveCD for the first step (unless you are using a new HD).
      Here is the how-to that I liked most from a quick google search:
      http://www.psychocats.net/ubuntu/separatehome
      Please, make a backup before working with partitions. BTW, doing it in a new install is way easier .
      Javier.
        I have read infos,thanks, i care about some links,adjustment files and desktop environments.and i'm already have partition for this from my old linux system, am i must do it throught live cd and not by my working system? Thanks...from Russia..
