Grub Problem
    Grub Problem
    Ok, so i installed kubuntu.
    First some info about my machine
    2 HDD's
    Ubuntu is installed on second hdd, so is grub, when i try to boot i get a "no such partition" error, and when i change it(pressing e twice) i get that error and sometimes, Cannot mount partition, i tried (1,1-1,5) all didnt work, how to fix this ?
    Re: Grub Problem
    This is fixable. You'll have to sort out some details using the following guide:
    How To GRUB Methods - Toolkit
    http://kubuntuforums.net/forums/inde...opic=3081671.0
    You will probably have to edit the boot menu called /boot/grub/menu.lst. But first, you must sort out where everything is on your two hard drives. Tip: use the geometry command (see the end of the How-to). You didn't mention if you have other operating systems or Windows, or other details.
      Re: Grub Problem
      Well i know how the second one is, it has 3 partitions and none of them work when put in grub
        Re: Grub Problem
        Well i installed kubuntu again(7.10), i put grub on my second hdd, grub loads, its pointing to the direct partition, but when i try to boot it sais failed to mount
          Re: Grub Problem
          Hmm, we'll need a little more info here.
          What partitions (and OS'es) do you have on HDD 1?
          What partitions (and OS'es) do you have on HDD 2?
          Which HDD is your BIOS set to boot from?
          If unsure, try this:
          Originally posted by Snowhog
          Let's 'see' what your system 'looks' like. Open a console and type:
          sudo fdisk -l
          copy and paste the output. Then type:
          cat /etc/fstab
