Shutdown problem-black screen-solutions
    Hello Kubuntu users,
    The problem I will describe here is a problem experienced by many users (including myself). It is going on for quite a long time now and all the solutions found so far did not work for me. In this post I gather all the solutions and I propose one of my own which worked for me in hope of helping anyone interested.
    The problem occurs when trying to shutdown/restart from the LogOut menu. The screen then just goes black or shows some small colored squares before the usplash appears and the computer hangs there. It does not respond to anything at all except for pressing the shutdown button for 5-6 seconds (hard reboot).
    There are three solutions proposed so far (none of them worked for me):
    1. First proposed solution:
    edit the /etc/kde3/kdm/kdmrc file and add or uncomment the following line in the [X-:*-Core] section (note the *):
    TerminateServer=true
    2. Second proposed solution:
    Instead of shutting down, first logout and then shutdown/restart from the KDM menu.
    3. Third proposed solution:
    Remove the usplash by editing the /boot/grub/menu.lst and removing the splash option. Usually the kernel line is something like
    ... ro quiet splash
    Just remove the splash so that it looks like this
    ....ro quiet
    My proposed solution is to get rid of the KDM and use GDM instead. So what I suggest is:
    install GDM and themes:
    sudo apt-get install gdm gdm-themes
    Once it finishes the installation it will ask you to select between KDM and GDM. You must select GDM. This workaround works flawlessly for me, I hope it will for you.
    Kubuntu 12.04 64-bit
    Re: Shutdown problem-black screen-solutions
    Nice to know you found another approach for the problem.
    BTW, does it install too many Gnome packages because of GDM?
      Well, I do not remember that. However , the GDM package depends on about 30 packages most of which are already installed for the KDE. So, I would say that it does not install too many Gnome packages.
        I tried this suggestion but it did not work.
        So I wanted to go back to KDM.
        I think I goofed up here. I went to the "System Setting" from K-Menu and in "System Services" I tried starting KDM again. But gave me an error saying it is not the default manager. So I clicked on GDM and clicked on Stop button.
        At this point the system went down. Now I am able to boot the computer only in Recovery Mode. Can anyone suggest how to start KDM from this point?
        Triple booting Kubuntu Intrepid with XP and Ubuntu Hardy <br />Intel Pentium DualCore 2 Ghz, 1 GB RAM Intel 945GM MoBo
          That's strange... Anyway, in recovery mode try
          sudo dpkg-reconfigure gdm
          and it will allow you to select between kdm and gdm again.
          Let me know how it goes.
            I’ll try to slip this here (sorry to interrupt) --
            Some feedback on Method #1, fwiw, fyi:
            Quote OP:
            “There are three solutions proposed so far (none of them worked for me):
            TerminateServer=true “
            It worked for me.
            I have a fresh download/install of 7.04, CD checked out OK (No Defects and MD5SUMS ok), downloaded all 199 MB of updates, etc., but no shutdown or restart from the K-Menu would work.
            The above solution fixed it.
            Hardware (very standard):
            Intel mobo D915GAVL, Intel CPU 530J 3 GHz, Seagate HDDs, Antec P/S, Sony DVD writer, embedded video (no video cards), NEC Accusync 750F CRT
              Tried this. It did ask me to select between the two. I selected GDM. However, it returned an error message saying
              invoke-rc.d: initscript gdm, action "reload" failed
              I also tried to reconfigure xserver-xorg (dpkg-reconfigure xxerver-xorg) and selected all the settings as required. However when I gave the command "startx" it returned messages saying screen not found.
              very puzzled
              will i need to reinstall Kubuntu?
                I am puzzled too. I guess you can still enter in recovery mode. So make sure that GDM has indeed stopped by
                sudo /etc/init.d/gdm stop
                then remove GDM
                sudo apt-get remove --purge gdm gdm-themes
                sudo apt-get autoremove --purge
                and then start KDM by
                sudo /etc/init.d/kdm start.
                If I remember correctly you do not need to do "startx" after the last command.
                  then remove GDM
                  Did as suggested. at last stage, it showed
                  Starting KDM... [OK]
                  After this, text prompt appeared and nothing else seemed to happen. So I rebooted (in normal mode this time)
                  After grub selection, only blank screen appeared. I tried Ctrl.+Alt+F2. It showed up the login prompt (in text mode only). I logged in and again tried the last command you suggested (sudo /etc/init.d/kdm start)
                  It returned the following
                  Starting K Display Manager: KDM already running
                  However no login splash screen or gui
                  Any way ahead?
                    Apparently, the display manager is working fine (KDM) but there is nothing to display. This means you probably messed up something you shouldn't have when you dpkg-reconfigured the xserver-xorg. You probably have a backup of the xorg.conf configuration before you reconfigured (probably something like xorg.conf~ or xorg.conf.20070819). So I suggest to use the backup.
                    cd /etc/X11/
                    mv xorg.conf xorg.conf.backup (save your current configuration)
                    mv xorg.conf~ xorg.conf
                    where xorg.conf~ is the backup you want to restore. I will wait for news.
                      how do i know which backup to use?
                      when I had done this 'reconfigure xserver' thing it gave me a file name as "/etc/X11/xorg.conf.20070819221053" as backup
                      shall i use the same?
                        perfect, it seems like you found your backup. So do the following:
                        cd /etc/X11
                        mv xorg.conf.20070819221053 xorg.conf
                        and then restart.
                          thank you my friend... everthing up and running as yesterday
                          by the way, can you suggest a good tutorial for shell commands
                            You are very welcome! Hmm... I really do not know of any good tutorial. However you can learn most of the things from the manual pages (e.g. man mv (from a terminal) or man:/mv (from konqueror)) and scattered searches on the internet.
                              A good reference to have on had is Learning the bash Shell, Third Edition published by O'Reilly books.
