tape drive problem
    tape drive problem
    I have a small problem getting a HP dat working on a hp dl380. I've read a few posts about similar problems on the ubuntu forum but nothing has helped.
    I have added st to /etc/modules and st is listed in lsmod but /dev/st0 is still not created.
    Dmesg doesnt show any info about the drive.
    Anybody got any ideas on how to solve this.
    Regards Kenneth
    Re: tape drive problem
    Well. It seems as if nobody had an answer so I'll post the solution if anybody else has the same problem.
    Add the following to a init.d start file.
    modprobe st
    echo "engage scsi" > /proc/driver/cciss/cciss0
    echo "rescan" > /proc/drive/cciss/cciss0
    Many thanks to Redhat support for supplying this info.
    Regards Kenneth
