Xorg problems on initial installation
    Hey all,
    Just downloaded and installed Kubuntu 6.06 Dapper Drake. Looks really cool so far, except for I've only just fixed a problem with xorg.conf which was supplied as default in the installation for some reason.
    Firstly, xorg.conf contains the following:
    Section "InputDevice"
     Driver    "wacom"
     Identifier  "stylus"
     Option    "Device"    "/dev/wacom"     # Change to
                               # /dev/input/event
                               # for USB
     Option    "Type"     "stylus"
     Option    "ForceDevice"  "ISDV4"        # Tablet PC ONLY
    EndSection
     Driver    "wacom"
     Identifier  "eraser"
                               # /dev/input/event
                               # for USB
     Option    "Type"     "eraser"
    EndSection
     Driver    "wacom"
     Identifier  "cursor"
                               # /dev/input/event
                               # for USB
     Option    "Type"     "cursor"
    EndSection
    Not sure if they're supposed to be in there or not? They dont cause a problem other than errors in the xorg log file, so will leave that in there until someone replies to this.
    The next thing though was a bigger problem. It had issues with my monitor that wasn't present in Breezy (or other distributions, as I could only fix this problem by downloading and running knoppix to get the right modelines). For hours I have been trying to get it to work at a resolution other than 640x480 (which is just selected as a default fail safe mode I believe). The installation routine did detect the monitor correctly with vert and horizontal sync/refresh rates set correctly for this monitor, but it never added any mode lines to the conf file and hence it couldnt set the video modes at all. I have fixed this by adding the following into the monitor section (I've included the whole monitor part of the file but I've only added the mode lines to get it to work).
    Section "Monitor"
    	Identifier	"Q90U Dvi"
    	Option		"DPMS"
    	HorizSync	31-67
    	VertRefresh	59-61
    	ModeLine "640x480"	 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
    	ModeLine "640x480" 43.16 640 680 744 848 480 481 484 509 -HSync +Vsync
    	# 768x576 @ 60.00 Hz (GTF) hsync: 35.82 kHz; pclk: 34.96 MHz
    	ModeLine "768x576" 34.96 768 792 872 976 576 577 580 597 -HSync +Vsync
    	# 768x576 @ 72.00 Hz (GTF) hsync: 43.27 kHz; pclk: 42.93 MHz
    	ModeLine "768x576" 42.93 768 800 880 992 576 577 580 601 -HSync +Vsync
    	# 768x576 @ 75.00 Hz (GTF) hsync: 45.15 kHz; pclk: 45.51 MHz
    	ModeLine "768x576" 45.51 768 808 888 1008 576 577 580 602 -HSync +Vsync
    	# 768x576 @ 85.00 Hz (GTF) hsync: 51.42 kHz; pclk: 51.84 MHz
    	ModeLine "768x576" 51.84 768 808 888 1008 576 577 580 605 -HSync +Vsync
    	# 768x576 @ 100.00 Hz (GTF) hsync: 61.10 kHz; pclk: 62.57 MHz
    	ModeLine "768x576" 62.57 768 816 896 1024 576 577 580 611 -HSync +Vsync
    	# 800x600 @ 100.00 Hz (GTF) hsync: 63.60 kHz; pclk: 68.18 MHz
    	ModeLine "800x600" 68.18 800 848 936 1072 600 601 604 636 -HSync +Vsync
    	# 1024x768 @ 100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz
    	ModeLine "1024x768" 113.31 1024 1096 1208 1392 768 769 772 814 -HSync +Vsync
    	# 1152x864 @ 60.00 Hz (GTF) hsync: 53.70 kHz; pclk: 81.62 MHz
    	ModeLine "1152x864" 81.62 1152 1216 1336 1520 864 865 868 895 -HSync +Vsync
    	# 1152x864 @ 85.00 Hz (GTF) hsync: 77.10 kHz; pclk: 119.65 MHz
    	ModeLine "1152x864" 119.65 1152 1224 1352 1552 864 865 868 907 -HSync +Vsync
    	# 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz
    	ModeLine "1152x864" 143.47 1152 1232 1360 1568 864 865 868 915 -HSync +Vsync
    	# 1280x960 @ 72.00 Hz (GTF) hsync: 72.07 kHz; pclk: 124.54 MHz
    	ModeLine "1280x960" 124.54 1280 1368 1504 1728 960 961 964 1001 -HSync +Vsync
    	# 1280x960 @ 75.00 Hz (GTF) hsync: 75.15 kHz; pclk: 129.86 MHz
    	ModeLine "1280x960" 129.86 1280 1368 1504 1728 960 961 964 1002 -HSync +Vsync
    	# 1280x960 @ 100.00 Hz (GTF) hsync: 101.70 kHz; pclk: 178.99 MHz
    	ModeLine "1280x960" 178.99 1280 1376 1520 1760 960 961 964 1017 -HSync +Vsync
    	# 1280x1024 @ 100.00 Hz (GTF) hsync: 108.50 kHz; pclk: 190.96 MHz
    	ModeLine "1280x1024" 190.96 1280 1376 1520 1760 1024 1025 1028 1085 -HSync +Vsync
    	# 1400x1050 @ 60.00 Hz (GTF) hsync: 65.22 kHz; pclk: 122.61 MHz
    	ModeLine "1400x1050" 122.61 1400 1488 1640 1880 1050 1051 1054 1087 -HSync +Vsync
    	# 1400x1050 @ 72.00 Hz (GTF) hsync: 78.77 kHz; pclk: 149.34 MHz
    	ModeLine "1400x1050" 149.34 1400 1496 1648 1896 1050 1051 1054 1094 -HSync +Vsync
    	# 1400x1050 @ 75.00 Hz (GTF) hsync: 82.20 kHz; pclk: 155.85 MHz
    	ModeLine "1400x1050" 155.85 1400 1496 1648 1896 1050 1051 1054 1096 -HSync +Vsync
    	# 1400x1050 @ 85.00 Hz (GTF) hsync: 93.76 kHz; pclk: 179.26 MHz
    	ModeLine "1400x1050" 179.26 1400 1504 1656 1912 1050 1051 1054 1103 -HSync +Vsync
    	# 1400x1050 @ 100.00 Hz (GTF) hsync: 111.20 kHz; pclk: 214.39 MHz
    	ModeLine "1400x1050" 214.39 1400 1512 1664 1928 1050 1051 1054 1112 -HSync +Vsync
    	# 1600x1200 @ 100.00 Hz (GTF) hsync: 127.10 kHz; pclk: 280.64 MHz
    	ModeLine "1600x1200" 280.64 1600 1728 1904 2208 1200 1201 1204 1271 -HSync +Vsync
    	# 1920x1200 @ 60.00 Hz (GTF) hsync: 74.52; pclk: 193.16 MHz
    	Modeline "1920x1200" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -HSync +HSync
    EndSection
    How is it knoppix can set those lines just fine, but kubuntu fails to do so? (Except for instance in Breezy which did work ok).
    Anyway at least I've got it working at 1280x1024 now, just took a few hours of tweaking and fiddling etc. Perhaps this could be a fix for the next version of kubuntu?
    Re: Xorg problems on initial installation
    It is safe to remove those lines (you have to remove the corresponding lines from "input devices" too or x11 refuses to start).
    It must be a bug in Xserver ver. 7.0 (another one), I don't have such devices.
